[Nek5000-users] History points
Wed May 5 12:22:03 CDT 2010
Hello Nek's,
I have a few questions on how to use the history points.
I have seen on the wiki the following stuff:
>     History points
> Specify grid points to monitor the specified variables in time. Example:
> ***** HISTORY AND INTEGRAL DATA *****
> 1    POINTS.  Var, Hcode, I, J, K, IEL
>              UV P    H    2  2  1  4
> NOTE:
>     * Make sure LHIS in SIZEu is large enough
I bet Var stands for variable, but what do Hcode, I, J, K, and IEL stand
for ?
Once you have specified the location of your history point, let's say a
point on the centerline of a stenotic flow at whatever streamwise
station, how do you get the data concerning this history point? Do you
have to change anything else in the output specification section ? I
have tried to add the wiki lines up there directly in my blah.rea but
once I ran the code I did not get any new files other than the expected
blah.fld's.
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100505/cb55426f/attachment.html>
