[Nek5000-users] Boundary condition "I"
Tue May 4 05:25:43 CDT 2010
These things are not related to BCs. The 'I' in HCODE means integral. In connect2  we check if one ob the boundary condition tags _ends_ with an 'i' (don't mess it up with 'I  ').
hth,
Stefan
On May 4, 2010, at 12:21 AM, nek5000-users at lists.mcs.anl.gov wrote:
> [root at frank nek]# grep -F "'I'" *
> bdry.f:            IF ( HCODE(10,IH) .EQ. 'I' ) THEN
> navier5.f:         IF (HCODE(10,II).NE.'I') GOTO 100
> navier5.f:        if (hcode(10,ii).EQ.'I') then
> prepost.f:            IF(HCODE(10,IH).EQ.'I') then
> prepost.f:         IF (HCODE(10,II).NE.'I') GOTO 100
> prepost.f:      IF ( HCODE(10,II).NE.'I') GOTO 100
> prepost.f:      IF ( HCODE(10,II).NE.'I') GOTO 200
> [root at frank nek]# grep -F "'i'" *
> connect2.f:c
> IF(CBC3(3:3).NE.'i')NLINES=BC(1,ISIDE,IEL,IFIELD)
> connect2.f:c
> IF(CBC3(3:3).EQ.'i')NLINES=BC(4,ISIDE,IEL,IFIELD)
> On Tue, 2010-05-04 at 12:17 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Well, it does not show up the in routines which apply the boundary conditions.
>> Where does is it appear in the code?
>> Stefan
>> On May 4, 2010, at 12:10 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello Stefan,
>>> It is not listed there.  It does appears in the code in more than a few
>>> places, so it appears to not fall under the statement "Anything else
>>> will be taken as zero flux".
>>> Cheers,
>>> Frank
>>> On Tue, 2010-05-04 at 12:01 +0200, nek5000-users at lists.mcs.anl.gov
>>> wrote:
>>>> check here: https://nek5000.mcs.anl.gov/index.php/Boundary_Definition
>>>> Stefan
>>>> On May 3, 2010, at 11:47 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hello all,
>>>>> Could anyone tell me what the boundary condition "I" means?
>>>>> Cheers,
>>>>> Frank
>>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>>> Technische Universität Wien (Technical University of Vienna)
>>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>>> Mechanics and Heat Transfer)
>>>>> Resselgasse 3
>>>>> 1040 Wien
>>>>> Tel: +4315880132232
>>>>> Fax: +4315880132299
>>>>> Cell:+436765203470
>>>>> fmuldoo (skype)
>>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> Resselgasse 3
>>> 1040 Wien
>>> Tel: +4315880132232
>>> Fax: +4315880132299
>>> Cell:+436765203470
>>> fmuldoo (skype)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
