[Nek5000-users] Boundary condition "I"
Mon May 3 17:21:27 CDT 2010
[root at frank nek]# grep -F "'I'" *
bdry.f:            IF ( HCODE(10,IH) .EQ. 'I' ) THEN
navier5.f:         IF (HCODE(10,II).NE.'I') GOTO 100
navier5.f:        if (hcode(10,ii).EQ.'I') then
prepost.f:            IF(HCODE(10,IH).EQ.'I') then
prepost.f:         IF (HCODE(10,II).NE.'I') GOTO 100
prepost.f:      IF ( HCODE(10,II).NE.'I') GOTO 100
prepost.f:      IF ( HCODE(10,II).NE.'I') GOTO 200
[root at frank nek]# grep -F "'i'" *
connect2.f:c
IF(CBC3(3:3).NE.'i')NLINES=BC(1,ISIDE,IEL,IFIELD)
connect2.f:c
IF(CBC3(3:3).EQ.'i')NLINES=BC(4,ISIDE,IEL,IFIELD)
On Tue, 2010-05-04 at 12:17 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> Well, it does not show up the in routines which apply the boundary conditions.
> Where does is it appear in the code?
> Stefan
> On May 4, 2010, at 12:10 AM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello Stefan,
> > It is not listed there.  It does appears in the code in more than a few
> > places, so it appears to not fall under the statement "Anything else
> > will be taken as zero flux".
> > Cheers,
> > Frank
> > On Tue, 2010-05-04 at 12:01 +0200, nek5000-users at lists.mcs.anl.gov
> > wrote:
> >> check here: https://nek5000.mcs.anl.gov/index.php/Boundary_Definition
> >> Stefan
> >> On May 3, 2010, at 11:47 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> Hello all,
> >>> Could anyone tell me what the boundary condition "I" means?
> >>> Cheers,
> >>> Frank
> >>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> >>> Technische Universität Wien (Technical University of Vienna)
> >>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> >>> Mechanics and Heat Transfer)
> >>> Resselgasse 3
> >>> 1040 Wien
> >>> Tel: +4315880132232
> >>> Fax: +4315880132299
> >>> Cell:+436765203470
> >>> fmuldoo (skype)
> >>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> >>> _______________________________________________
> >>> Nek5000-users mailing list
> >>> Nek5000-users at lists.mcs.anl.gov
> >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> > Resselgasse 3
> > 1040 Wien
> > Tel: +4315880132232
> > Fax: +4315880132299
> > Cell:+436765203470
> > fmuldoo (skype)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
