[Nek5000-users] Warning Message : L1/L2 DIV(V)
Mon May 3 15:52:25 CDT 2010
Hi Stefan,
I am running an LES with the following parameters:
1. p101=3 and p103 =0.05(filter weight).
2. De aliasing enabled and set to 16. (lxd = 16 )
4. lx1 = 11
3. Yes, IFCHAR is on and a CFL close to 2 is used.
4. I add some divergence to the flow outlet using the same procedure
detailed in the examples.
This is my first flow through the domain and I intend to run it for a couple
more depending on the results.
Thank you for the info on order of interpolation polynomial. I would have to
refine my domain in order to match the resolution by reducing the lx1. I
will look into it.
Please find attached pieces of rea and log file stacked together in the
attachment. Thanks.
Regards
Shriram
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100503/a46b948b/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100503/a46b948b/attachment.obj>
