[Nek5000-users] [*] Re: [*] Re: Postprocessing
Wed Mar 31 09:14:25 CDT 2010
Dear Paul,
     Does the code that you gave to output vorticity work for 2D too?
I'm trying to simulate a lid driven cavity at Re=10000 and the velocity
seems fine but nothing shows up on the vorticity plot (I've attached
both of them).
Mani chandra
On 03/27/2010 06:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Mani,
> Nek currently supports only a few output fields:
> X, V, p, T, ps1, ... ,psn
> X = coords
> V = velocity
> p = pressure
> T = temperature
> psj = jth passive scalar
> The call
>        call outpost(vort(1,1),vort(1,2),vort(1,3),pr,t,'vrt')
> would generate a file "vrtmycase0.f..." with vorticity
> components in place of V=(vx,vy,vz).
> To view these with visit, load the vrt... file and request
> to look at "velocity"  (VisIt thinks the field is a velocity
> field).
> Paul
> On Sat, 27 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> On 03/24/2010 09:58 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Mani,
>>> It somewhat depends on what you're after.
>>> You can use postx and compute the vorticity there --- it is
>>> only 32 bit but it does allow you to compute the vorticity
>>> for any existing velocity data in the (older) .fld file
>>> output format.
>>> Alternatively, if you're using VisIt or some other analysis
>>> tool, or doing run-time analysis, you can compute the vorticity
>>> at runtime.  If you wish to output the vorticity field, you can
>>> do so, e.g., as follows:
>>> c-----------------------------------------------------------------------
>>>       subroutine userchk
>>>       include 'SIZE'
>>>       include 'TOTAL'
>>>       parameter(lt=lx1*ly1*lz1*lelv)
>>>       common /scrns/ vort(lt,3),w1(lt),w2(lt)
>>>       if (mod(istep,iostep).eq.0) then
>>>          call comp_vort3(vort,w1,w2,vx,vy,vz)
>>>       endif
>>>       return
>>>       end
>>> This would generate an output "vrtmy_case..." if your .rea file is
>>> my_case.rea
>>> Any of the post-processing tools could then read the vrt.... files
>>> and treat the vorticity as the velocity vector field.
>>> As I say, not exactly sure what you have in mind, but this is one
>>> possible approach.
>>> Paul
>>> On Wed, 24 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Dear Nek devs,
>>>>    I'm a bit confused regarding postprocessing. Is one supposed to
>>>> run a simulation and then run nek5k again to load the fld files
>>>> using load_fld() for postprocessing? Or can one compute the desired
>>>> quantities after every time step using userchk() and then output
>>>> them in a file? For example, how can I compute the vorticity using
>>>> the differential operators defined in the code? After computing the
>>>> vorticity, can it be outputted using the same fld files?
>>>> Regards,
>>>> Mani chandra
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Dear Paul,
>>    The files generated by the code in usr_chk(), vrtmy_case0.f* do
>> not seem to have vorticity in them when I view them in Visit through
>> the database file. They only seem to have pressure, x, y, z
>> components of velocity and the velocity magnitude. Could something be
>> wrong?
>> Mani chandra
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100331/b4fe990b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100331/b4fe990b/attachment-0001.png>
