[Nek5000-users] makenek problem (fwd)
Mon Mar 22 08:01:55 CDT 2010
David,
it seems like you did an 'svn update'  and you ended up with unresolved conflicts. Just delete the nek directory in the trunk and run
svn update nek
Also, please make sure to use an up-to-date makenek which we provide together with the source.
#Stefan
On Mar 22, 2010, at 1:53 PM, nek5000-users at lists.mcs.anl.gov wrote:
> David,
> We've been having some makenek issues of late.
> I'm forwarding to the users list so that it comes
> to the attention of all the developers.
> Hopefully we'll get it straightened out for you in the
> next 48 hours, though Stefan and I are both on travel.
> Best regards,
> Paul
> ---------- Forwarded message ----------
> Date: Mon, 22 Mar 2010 02:15:50 -0400
> From: David Goluskin <goluskin at gmail.com>
> To: Aleksandr Obabko <obabko at mcs.anl.gov>, Paul Fischer <fischer at mcs.anl.gov>
> Subject: makenek problem
> Hi Aleks,
> I'm suddenly having problems running makenek to compile nek5000.  I have
> checked out the latest version, 444.  I'm trying to run the (unmodified)
> makenek script on the ray0.usr file, and I get some errors.  The same thing
> happens when I try the usr file from a different example.  I'm not sure if I
> had to customize makenek previously, but I don't remember doing so.  A lot
> of makenek runs with no problems, but 6 errors come up at one point.  The
> errors are:
> mpif77 -c  -O2 -r8 -cpp -fno-second-underscore -DMPI -DLONGINT8
> -I/home/goluskin/nek5_svn/trunk/nek
> /home/goluskin/nek5_svn/trunk/nek/comm_mpi.f
> <<<<<<< .mine
> pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 13, Column = 1
>  The characters found in the label field are not valid.
> pathf95-95 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 13, Column = 9
>  The real constant must contain digits in the whole and/or the fractional
> part of the constant.
>     &,'| Version:  1.0rc1 / SVN r444M                             |'
> pathf95-66 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 14, Column = 7
>  A defined operator is missing the "." delimiter.
> pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 15, Column = 1
> pathf95-197 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 15, Column = 7
>  Unexpected syntax: "EOS" was expected but found "=".
>>>>>>>> .r428
> pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 17, Column = 1
> Do you have any idea what's wrong here?  If it's easier for you to address
> this issue by phone, I am free 4-5 PM EST tomorrow, and I can call you then.
> Thanks very much,
> David
> Nek5000-users mailing list
