[Nek5000-users] makenek problem (fwd)
Mon Mar 22 07:53:25 CDT 2010
David,
We've been having some makenek issues of late.
I'm forwarding to the users list so that it comes
to the attention of all the developers.
Hopefully we'll get it straightened out for you in the
next 48 hours, though Stefan and I are both on travel.
Best regards,
Paul
---------- Forwarded message ----------
Date: Mon, 22 Mar 2010 02:15:50 -0400
To: Aleksandr Obabko <obabko at mcs.anl.gov>, Paul Fischer <fischer at mcs.anl.gov>
Subject: makenek problem
Hi Aleks,
I'm suddenly having problems running makenek to compile nek5000.  I have
checked out the latest version, 444.  I'm trying to run the (unmodified)
makenek script on the ray0.usr file, and I get some errors.  The same thing
happens when I try the usr file from a different example.  I'm not sure if I
had to customize makenek previously, but I don't remember doing so.  A lot
of makenek runs with no problems, but 6 errors come up at one point.  The
errors are:
mpif77 -c  -O2 -r8 -cpp -fno-second-underscore -DMPI -DLONGINT8
-I/home/goluskin/nek5_svn/trunk/nek
/home/goluskin/nek5_svn/trunk/nek/comm_mpi.f
<<<<<<< .mine
pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 13, Column = 1
   The characters found in the label field are not valid.
pathf95-95 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 13, Column = 9
   The real constant must contain digits in the whole and/or the fractional
part of the constant.
      &,'| Version:  1.0rc1 / SVN r444M                             |'
pathf95-66 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 14, Column = 7
   A defined operator is missing the "." delimiter.
pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 15, Column = 1
pathf95-197 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 15, Column = 7
   Unexpected syntax: "EOS" was expected but found "=".
>>>>>>> .r428
pathf95-400 pathf95: ERROR PRINTHEADER, File = HEADER, Line = 17, Column = 1
Do you have any idea what's wrong here?  If it's easier for you to address
this issue by phone, I am free 4-5 PM EST tomorrow, and I can call you then.
Thanks very much,
David
