[Nek5000-users] Compute the derivatives
Tue Jun 8 07:43:14 CDT 2010
That's ok!
The SEM solution is by construction in C0 but not in C1.
Note: The jump in the derivative vanishes if N -> infty.
If you want to force the derivative to be in C0 just use dssum().
Hth,
Stefan
On Jun 8, 2010, at 2:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi all,
> Thanks for the tip Aleks.
> Anyway, I have another question. When I visualize the computed derivatives using VisIt or Tecplot, it appears that discontinuities exist at the interfaces between elements.
> Is that normal or did I screw up something when setting up the calculation ?
> Thanks,
> JC
> PS: Attached is a small portion of my computational domain on which one can clearly see the discontinuities.
> Nek5000-users mailing list
