[Nek5000-users] RE : Visualizing moving meshes in VisIT
Fri Jun 4 15:29:58 CDT 2010
Hi Michael,
thanks a lot, that worked well - and just recompiling the plugin (no need to
redo the whole program) is pretty fast too.
On the long run, it would be nice to have a switch somewhere in the GUI since
this Visit installation is also used for bigger, time-varying data, where I
guess rereading a non-changing mesh every time step will, as Hank pointed out
earlier, slow things down.
Thanks again,
Markus
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi Markus,
> I managed to get the moving mesh in VisIt by changing a line in the input
> plugin source code.
> You can easily download the source on VisIt website  (you can also find some
> plugin compilation documentation there) and then recompile the plugin after
> having done the following :
> in function GetMesh() change the last line from  :
>                           timestepToUseForMesh = 0;
> to :
>                           timestepToUseForMesh = ts;
> That works for me with VisIt 1.12.1
> hth,
> Michael B
> De : nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] de la part de
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Date d'envoi : vendredi 4 juin 2010 15:24
> À : nek5000-users at lists.mcs.anl.gov
> Objet : [Nek5000-users] Visualizing moving meshes in VisIT
> Frank, Hank,
> I am interested in visualizing moving meshes in VisIT. From previous
> posts, I read that you are working on that. Is it usable yet and how do
> I go about it?
> Thanks,
> Markus
> Nek5000-users mailing list
