[Nek5000-users] New Recycling BC based on interpolation
Fri Jul 16 16:25:22 CDT 2010
Hi Aleks,
Thank you very much for looking into this. I already have a question; I noticed that you marked several notes dealing with "RBC single inlet -- modify for other cases". I am assuming this means that you have one inlet that you want to recycle, but another inlet that you do not want to recycle, which just happens to be my case.
Can I distinguish in the rea between the two by "v1 " and "v2 " without giving genmap any problems, and then modify the checks in the usr file accordingly? Also, the subroutine rescale_inflow mentions to modify for multiple inlets as well but I do not see where any modification could/needs to be done for it.
- Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, July 16, 2010 3:03:52 PM GMT -06:00 US/Canada Central
Subject: [Nek5000-users] New Recycling BC based on interpolation
Hi Michael and Markus,
Here is a test case for an unsteady pipe flow with Michael's GambitPipe.rea file which sets inlet Recycling BCs based on interpolation from a cross-section downstream that you specify by a multiple of the inlet normal:
http://www.mcs.anl.gov/~obabko/z4.tgz
Let me know if you have any questions.
Best,
Aleks
Sent: Thursday, July 8, 2010 5:06:48 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] New Recycling BC method?
No worries, just checkin in to see how it was going, thanks for the update! Look forward to trying it out!
- Michael
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100716/fdd33d05/attachment.html>
