[Nek5000-users] r,s,t index for given point
Mon Jul 12 05:13:47 CDT 2010
fixed in r548.
Stefan
On Jul 12, 2010, at 10:49 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Markus,
> lglel reads "local to global element number" so input is
> local element number and output is global element number.
> I'll be seeing Stefan this week so I'm sure we can straighten
> out the interpolation routines.
> You're right about the other points - the ntotv wasn't flagged
> by my compiler and the .his file was taken care of by my own
> scripts, so I didn't catch either of them.  Sorry about that.
> I've updated the source so that those issues should be
> resolved.
> Paul
> On Mon, 12 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> that was not it, I'm afraid (though I thought gllel transforms from local to global).
>> But I also realized that the hpts routine does not deliver the correct values for me. To test this, I set up a simple 3d box with inflow, outflow and symmetry all around, Re very low, initial condition=boundary condition and 4 points.
>> Please find all files attached, the output for the first point is OK, but then the values seem to shift positions and don't make sense.
>> Also, when running it for 1 step or more, I get the error message:
>> dump history points
>> done :: dump history points
>> hisfile:
>> /Users/m0s1978/nektonruns/rectest/rectest.his
>> ERROR: .sch file already exists.  ierr=  1
>> And lastly, the newest repo won't compile, here is the error message:
>> Error: /Users/m0s1978/nek5trial/trunk/nek/drive2.f, line 1551: This name has already been assigned a data type.   [NVTOT]
>>     integer*8 ntot,nvtot,nptot
>> Thanks for any help,
>> Markus
>>> Hi Markus,
>>> It's possible that it's returning the local (to the processor)
>>> element number.  You would get the global (to the computational
>>> domain, defined by the .rea file) element number via:
>>>       integer e,eg
>>>       eg = lglel(e)
>>> Paul
>>> On Sun, 11 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi again,
>>>> Regarding finding element numbers (such as what gllel would return) for arbitrary history points, I was experimenting with the history point routine hpts a little and it seems that this function call:
>>>>       call findpts(inth_hpts,rcode,1,
>>>>    &                 proc,1,
>>>>    &                 elid,1,
>>>>    &                 rst,ndim,
>>>>    &                 dist,1,
>>>>    &                 pts(1,1),ndim,
>>>>    &                 pts(2,1),ndim,
>>>>    &                 pts(3,1),ndim,npoints)
>>>> does not return the same element number (elid) as it can be found in the .rea file, for instance.
>>>> For a handful of manually set points, I checked that the returned element number does not provide the right coordinates to enclose the desired point.
>>>> Is there a way to transform the function return or am I missing something else?
>>>> Thanks,
>>>> Markus
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
