[Nek5000-users] r,s,t index for given point
Mon Jul 12 03:49:20 CDT 2010
Hi Markus,
lglel reads "local to global element number" so input is
local element number and output is global element number.
I'll be seeing Stefan this week so I'm sure we can straighten
out the interpolation routines.
You're right about the other points - the ntotv wasn't flagged
by my compiler and the .his file was taken care of by my own
scripts, so I didn't catch either of them.  Sorry about that.
I've updated the source so that those issues should be
resolved.
Paul
On Mon, 12 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> that was not it, I'm afraid (though I thought gllel transforms from local to
> global).
> But I also realized that the hpts routine does not deliver the correct values
> for me. To test this, I set up a simple 3d box with inflow, outflow and
> symmetry all around, Re very low, initial condition=boundary condition and 4
> points.
> Please find all files attached, the output for the first point is OK, but
> then the values seem to shift positions and don't make sense.
> Also, when running it for 1 step or more, I get the error message:
> dump history points
> done :: dump history points
> hisfile:
> /Users/m0s1978/nektonruns/rectest/rectest.his
> ERROR: .sch file already exists.  ierr=  1
> And lastly, the newest repo won't compile, here is the error message:
> Error: /Users/m0s1978/nek5trial/trunk/nek/drive2.f, line 1551: This name has
> already been assigned a data type.   [NVTOT]
>      integer*8 ntot,nvtot,nptot
> Thanks for any help,
> Markus
>> Hi Markus,
>> It's possible that it's returning the local (to the processor)
>> element number.  You would get the global (to the computational
>> domain, defined by the .rea file) element number via:
>>        integer e,eg
>>        eg = lglel(e)
>> Paul
>> On Sun, 11 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi again,
>>> Regarding finding element numbers (such as what gllel would return) for
>>> arbitrary history points, I was experimenting with the history point
>>> routine hpts a little and it seems that this function call:
>>>        call findpts(inth_hpts,rcode,1,
>>>     &                 proc,1,
>>>     &                 elid,1,
>>>     &                 rst,ndim,
>>>     &                 dist,1,
>>>     &                 pts(1,1),ndim,
>>>     &                 pts(2,1),ndim,
>>>     &                 pts(3,1),ndim,npoints)
>>> does not return the same element number (elid) as it can be found in the
>>> .rea file, for instance.
>>> For a handful of manually set points, I checked that the returned element
>>> number does not provide the right coordinates to enclose the desired
>>> point.
>>> Is there a way to transform the function return or am I missing something
>>> else?
>>> Thanks,
>>> Markus
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
