[Nek5000-users] Averaging *.f files
Fri Jul 9 18:14:15 CDT 2010
Yes -
call avg_all on each step --- but set p68 = 5000 (say) to get the
result only every 5000 steps.  After each result the avg is reset to zero
and the averaging process starts over
On Fri, 9 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Shriram,
> If you call avg_all more often than you dump the field files, the averages
> come out smoother.
> I'm not familiar with the C routine but I can take a look unless somebody
> else can answer your question right away.
> Best.
> Aleks
> On Jul 9, 2010, at 6:00 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello,
>> I would like to look at the average values of a bunch of blah.f ( not the
>> fld format) files. I noticed that under tools directory, there is a .c code
>> to do a similar operation.
>> Could anyone brief the procedure for using it ?
>> Is it better to use this routine or directly compute statistical quantities
>> at run time using avg_all routine ?
>> Regards
>> Shriram
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
