[Nek5000-users] Averaging *.f files
Fri Jul 9 18:10:27 CDT 2010
Hi Shriram,
If you call avg_all more often than you dump the field files, the
averages come out smoother.
I'm not familiar with the C routine but I can take a look unless
somebody else can answer your question right away.
Best.
Aleks
On Jul 9, 2010, at 6:00 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> I would like to look at the average values of a bunch of blah.f
> ( not the fld format) files. I noticed that under tools directory,
> there is a .c code to do a similar operation.
> Could anyone brief the procedure for using it ?
> Is it better to use this routine or directly compute statistical
> quantities at run time using avg_all routine ?
> Regards
> Shriram
> Nek5000-users mailing list
