[Nek5000-users] New Recycling BC method?
Thu Jul 8 17:06:48 CDT 2010
No worries,  just checkin in to see how it was going, thanks for the update! Look forward to trying it out!
- Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, July 8, 2010 4:57:05 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] New Recycling BC method?
Hi Michael, I think it's close... We've been swamped over the past week(s) w/ a major proposal but hopefully the BC will be done by tomorror. Paul On Thu, 8 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Hi Paul, > > > > Do you have any updates regarding this?  Thanks for any information. > > > > - Michael > > > ----- Original Message ----- > From: nek5000-users at lists.mcs.anl.gov > To: nek5000-users at lists.mcs.anl.gov > Sent: Sunday, June 20, 2010 8:12:14 PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New Recycling BC method? > > > Hi Michael, > > We're working on an interpolation-based approach. > >> From the file you sent I can see that it could in general > be confusing w/ the old approach. > > Paul > > PS - was the file you sent just a test, or for production >       purposes?  I think more refinement near the walls would >       normally be in order. > > > > On Sun, 20 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > >> Hi Paul, >> >> Were you able to find a solution for this? >> >> I was able to establish a new connectivity matrix for connecting an >> arbitrary inlet plane to an outflow plane that you specifiy by a number of >> elements. This could be called once at the beginning. I'm not sure how to >> use it though but it is a positive start. >> >> - Michael >> >> On Jun 16, 2010, at 10:00 PM, nek5000-users at lists.mcs.anl.gov wrote: >> >>> Sounds great!  Thanks for looking into this! >>> >>> >>> >>> - Michael >>> >>> >>> ----- Original Message ----- >>> From: nek5000-users at lists.mcs.anl.gov >>> To: nek5000-users at lists.mcs.anl.gov >>> Sent: Wednesday, June 16, 2010 9:58:53 PM GMT -06:00 US/Canada Central >>> Subject: Re: [Nek5000-users] New Recycling BC method? >>> >>> Michael, got it... I should be able to send a fix by morning that will >>> work for any instances in which slab at location A has same (arbitrary) >>> topology orientation as slab at location B, as is the case in the example >>> you sent. This won't cover all cases but would likely cover 90%. hth, Paul >>> On Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Paul, > >>>>>> See attached for the rea. Thanks, > > > > Michael > > > ----- >>> Original Message ----- > From: nek5000-users at lists.mcs.anl.gov > To: >>> nek5000-users at lists.mcs.anl.gov > Sent: Wednesday, June 16, 2010 9:47:29 >>> PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New >>> Recycling BC method? > > 960 is ok On Wed, 16 Jun 2010, >>> nek5000-users at lists.mcs.anl.gov wrote: > > > Paul, > > > > The rea I have >>> now from matlab/gambit has 960 elements.  Do you want me to create >>> another, smaller rea that may make it easier to work with? > > > > The >>> geometry by the way is a simple pipe flow. > > > > - Michael > > > ----- >>> Original Message ----- > From: nek5000-users at lists.mcs.anl.gov > To: >>> nek5000-users at lists.mcs.anl.gov > Sent: Wednesday, June 16, 2010 9:39:59 >>> PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New >>> Recycling BC method? > > Hi Micheal, I agree completely that it's best to >>> avoid mix & match meshing. If you want to send me a gzipped .rea file >>> produced by Gambit, I can take a look and see if I have any ideas. Paul On >>> Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Hi Paul, > >>>>>> Thanks for the reply.  The reason for the interest is due to the >>> Gambit to Nek matlab code. We have had great success importing complex >>> geometries with it, but no w we run into the issue of the recycling >>> boundary condition.  Gambit's ordering of the elements is not always >>> consistent which makes it impossible to use the current technique. > > > > >>> Our solution was to create the portion that has the recycling in prex and >>> then merge it with the complex part created in Gambit. However, this is >>> proving to be very time consuming and troublesome (Element Mismatch >>> Errors).  So, to avoid this I would like to come up with a new recycling >>> method that does not depend on the elements being in a specific order. My >>> u nderstanding is that the current method looks at the inflow, counts a >>> certain number of elements up, copies this outflow from face 6 and puts it >>> back into the inflow face 5. > > > > What I would like to do is replace >>> how the inflow plane is connected to the outflow plane. My idea was to use >>> the connectivity matrix to figure out what the element numbers and outflow >>> faces are at a certain distance away from the inflow plane, and use t hese >>> faces to connect.  The cross-section for the inflow and outflow plane >>> would be the same, but you couldn't necessarily say that it is located, >>> say inflow + 30 elements for example, OR that the outflow and inflow faces >>> are all the same (face 5 for inflow, face 6 for outflow for example).  > > >>>>> Do you think this is possible? In a way, you would be creating a new >>> connectivity matrix that governs the recycling BC. > > > > Thanks! > > - >>> Michael M. > > > ----- Original Message ----- > From: nek5000-users at lists. >>> mcs . anl .gov > To: nek5000-use rs at lists. mcs . anl .gov > Sent: >>> Wednesday, June 16, 2010 9:08:00 PM GMT -06:00 US/Canada Central > >>> Subject: Re: [Nek5000-users] New Recycling BC method? > > Hi Michael, >>> Access to the connectivity array wouldn't help in this case, given that >>> the recycling bc needs to establish a _new_ connectivity that has nothing >>> to do with the existing one. The examples use this approach of >>> establishing a new connectivity. I'm confident that we ca n make the >>> existing approach for any mesh that can legitimally employ the recycling >>> bc - i.e., any mesh that has the same cross-sectional distribution of >>> elements at the two planes of interest. An alternative is to use the >>> general purpose interpolation routines. There may (or may not) be a >>> performance issue -- we're looking into this w/ the help of a summer >>> student. Please let me know if I can assist you w/ your specific case. >>> Paul > I am still trying to figure this idea out, but I think I would need >>> to > access the connectivity/boundary condition information that is >>> contained > in the rea file. Does anyone know the array, or what to call >>> in order to > access this in the usr file?  Thanks again for a ny help! > >>>>>> - Michael M. > > > ----- Original Message ----- > From: >>> nek5000-users at lists. mcs . anl .gov > To: " Nekton User List" > Sent: >>> Tuesday, June 15, 2010 9:02:00 PM GMT -06:00 US/Canada Central > Subject: >>> [Nek5000-users] New Recycling BC method? > > > > > Hello All, > > > > I am >>> wondering if there is another technique to set up a recycling boundary >>> condition that does not depend on the elements being in a certain order >>> (say based on element coordinates for instance)?   I would like to pick >>> the recycling plane based on a given offset distance rather than a number >>> of elements. > > > > Also, the outflow plane faces may not all necessarily >>> be face 6 (and face 5 for the inflow plane). > > > > I have tried going >>> through the examples where a recycling BC is used however I am finding it >>> difficult to understand as my knowledge of Fortan is still growing. Thanks >>> for any help anyone can provide with this idea. > > > > Regards, > > >>> Michael M. > > >   > ___________________ ____________________________ >>> Nek5000-users mailing list Nek5000-users at lists. mcs . anl .gov https >>> ://lists. mcs . anl .gov/mailman/ listinfo /nek5000-users > >>> _______________________________________________ Nek5000-users mailing list >>> Nek5000-users at lists. mcs . anl .gov https :/ /lists. mcs . anl >>> .gov/mailman/ listinfo /nek5000-users > >>> _______________________________________________ Nek5000-users mailing list >>> Nek5000-users at lists.mcs.anl.gov >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users > >>> _______________________________________________ Nek5000-users mailing list >>> Nek5000-users at lists.mcs.anl.gov >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users >>> _______________________________________________ Nek5000-users mailing list >>> Nek5000-users at lists.mcs.anl.gov >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users >>> >>> _______________________________________________ >>> Nek5000-users mailing list >>> Nek5000-users at lists.mcs.anl.gov >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users > _______________________________________________ > Nek5000-users mailing list > Nek5000-users at lists.mcs.anl.gov > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users >
_______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100708/2bdccab5/attachment.html>
