[Nek5000-users] New Recycling BC method?
Thu Jul 8 16:57:05 CDT 2010
Hi Michael,
I think it's close... We've been swamped over the past week(s)
w/ a major proposal but hopefully the BC will be done by tomorror.
Paul
On Thu, 8 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Do you have any updates regarding this?  Thanks for any information.
> - Michael
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Sunday, June 20, 2010 8:12:14 PM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] New Recycling BC method?
> Hi Michael,
> We're working on an interpolation-based approach.
>> From the file you sent I can see that it could in general
> be confusing w/ the old approach.
> Paul
> PS - was the file you sent just a test, or for production
>       purposes?  I think more refinement near the walls would
>       normally be in order.
> On Sun, 20 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> Were you able to find a solution for this?
>> I was able to establish a new connectivity matrix for connecting an
>> arbitrary inlet plane to an outflow plane that you specifiy by a number of
>> elements. This could be called once at the beginning. I'm not sure how to
>> use it though but it is a positive start.
>> - Michael
>> On Jun 16, 2010, at 10:00 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Sounds great!  Thanks for looking into this!
>>> - Michael
>>> Sent: Wednesday, June 16, 2010 9:58:53 PM GMT -06:00 US/Canada Central
>>> Michael, got it... I should be able to send a fix by morning that will
>>> work for any instances in which slab at location A has same (arbitrary)
>>> topology orientation as slab at location B, as is the case in the example
>>> you sent. This won't cover all cases but would likely cover 90%. hth, Paul
>>> On Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Paul, >
>>>>>> See attached for the rea. Thanks, > > > > Michael > > > -----
>>> Original Message ----- > From: nek5000-users at lists.mcs.anl.gov > To:
>>> nek5000-users at lists.mcs.anl.gov > Sent: Wednesday, June 16, 2010 9:47:29
>>> PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New
>>> Recycling BC method? > > 960 is ok On Wed, 16 Jun 2010,
>>> nek5000-users at lists.mcs.anl.gov wrote: > > > Paul, > > > > The rea I have
>>> now from matlab/gambit has 960 elements.  Do you want me to create
>>> another, smaller rea that may make it easier to work with? > > > > The
>>> geometry by the way is a simple pipe flow. > > > > - Michael > > > -----
>>> nek5000-users at lists.mcs.anl.gov > Sent: Wednesday, June 16, 2010 9:39:59
>>> Recycling BC method? > > Hi Micheal, I agree completely that it's best to
>>> avoid mix & match meshing. If you want to send me a gzipped .rea file
>>> produced by Gambit, I can take a look and see if I have any ideas. Paul On
>>> Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Hi Paul, >
>>>>>> Thanks for the reply.  The reason for the interest is due to the
>>> Gambit to Nek matlab code. We have had great success importing complex
>>> geometries with it, but no w we run into the issue of the recycling
>>> boundary condition.  Gambit's ordering of the elements is not always
>>> consistent which makes it impossible to use the current technique. > > > >
>>> Our solution was to create the portion that has the recycling in prex and
>>> then merge it with the complex part created in Gambit. However, this is
>>> proving to be very time consuming and troublesome (Element Mismatch
>>> Errors).  So, to avoid this I would like to come up with a new recycling
>>> method that does not depend on the elements being in a specific order. My
>>> u nderstanding is that the current method looks at the inflow, counts a
>>> certain number of elements up, copies this outflow from face 6 and puts it
>>> back into the inflow face 5. > > > > What I would like to do is replace
>>> how the inflow plane is connected to the outflow plane. My idea was to use
>>> the connectivity matrix to figure out what the element numbers and outflow
>>> faces are at a certain distance away from the inflow plane, and use t hese
>>> faces to connect.  The cross-section for the inflow and outflow plane
>>> would be the same, but you couldn't necessarily say that it is located,
>>> say inflow + 30 elements for example, OR that the outflow and inflow faces
>>> are all the same (face 5 for inflow, face 6 for outflow for example).  > >
>>>>> Do you think this is possible? In a way, you would be creating a new
>>> connectivity matrix that governs the recycling BC. > > > > Thanks! > > -
>>> Michael M. > > > ----- Original Message ----- > From: nek5000-users at lists.
>>> mcs . anl .gov > To: nek5000-use rs at lists. mcs . anl .gov > Sent:
>>> Wednesday, June 16, 2010 9:08:00 PM GMT -06:00 US/Canada Central >
>>> Subject: Re: [Nek5000-users] New Recycling BC method? > > Hi Michael,
>>> Access to the connectivity array wouldn't help in this case, given that
>>> the recycling bc needs to establish a _new_ connectivity that has nothing
>>> to do with the existing one. The examples use this approach of
>>> establishing a new connectivity. I'm confident that we ca n make the
>>> existing approach for any mesh that can legitimally employ the recycling
>>> bc - i.e., any mesh that has the same cross-sectional distribution of
>>> elements at the two planes of interest. An alternative is to use the
>>> general purpose interpolation routines. There may (or may not) be a
>>> performance issue -- we're looking into this w/ the help of a summer
>>> student. Please let me know if I can assist you w/ your specific case.
>>> Paul > I am still trying to figure this idea out, but I think I would need
>>> to > access the connectivity/boundary condition information that is
>>> contained > in the rea file. Does anyone know the array, or what to call
>>> in order to > access this in the usr file?  Thanks again for a ny help! >
>>>>>> - Michael M. > > > ----- Original Message ----- > From:
>>> nek5000-users at lists. mcs . anl .gov > To: " Nekton User List" > Sent:
>>> Tuesday, June 15, 2010 9:02:00 PM GMT -06:00 US/Canada Central > Subject:
>>> [Nek5000-users] New Recycling BC method? > > > > > Hello All, > > > > I am
>>> wondering if there is another technique to set up a recycling boundary
>>> condition that does not depend on the elements being in a certain order
>>> (say based on element coordinates for instance)?   I would like to pick
>>> the recycling plane based on a given offset distance rather than a number
>>> of elements. > > > > Also, the outflow plane faces may not all necessarily
>>> be face 6 (and face 5 for the inflow plane). > > > > I have tried going
>>> through the examples where a recycling BC is used however I am finding it
>>> difficult to understand as my knowledge of Fortan is still growing. Thanks
>>> for any help anyone can provide with this idea. > > > > Regards, > >
>>> Michael M. > > >   > ___________________ ____________________________
>>> Nek5000-users mailing list Nek5000-users at lists. mcs . anl .gov https
>>> ://lists. mcs . anl .gov/mailman/ listinfo /nek5000-users >
>>> _______________________________________________ Nek5000-users mailing list
>>> Nek5000-users at lists. mcs . anl .gov https :/ /lists. mcs . anl
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users >
