[Nek5000-users] mixed Velocity BC's
Fri Dec 31 09:40:22 CST 2010
Ultimately I'd like to be able to do this on any general surface.  Basically, impose a slip velocity in the streamwise direction with a specified gradient (so w_y=0 and u_y=const in a y-plane), no penetration in the wall-normal (v=0).
Andrew
On Dec 31, 2010, at 9:29 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Andrew,
> On what type of surface do you want this?  (z plane?, y plane?...?)
> Also, if y-plane, wouldn't it be:
>   v=0
>   w_y = 0
>   u_y = const
> (Or am I totally missing what you're trying to do ?)
> Cheers,
> Paul
> On Thu, 30 Dec 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Howdy Neks,
>> Has anyone tried or know how to implement a mixed velocity BC?  Such
>> as v=w=0 and du/dy=const?
>> Thanks
>> Andrew
>> Andrew Duggleby, Ph.D. '01
>> Assistant Professor
>> Department of Mechanical Engineering
>> Texas A&M University
>> College Station, TX  77843-3123
>> 109 Engineering Physics Building
>> http://www2.mengr.tamu.edu/FacultyProfiles/facultyinformation.asp?LastName=aduggleby
>> (979) 862-7835
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
