[Nek5000-users] postx & movie
    nek5000-users at lists.mcs.anl.gov
    Thu Aug 19 10:55:23 CDT 2010
Hi Frank,
If you still have the following problem then I think you can try to modify the following line in postnek9.f (line 939):
      call grab_window_raw(xpmn,ypmn,xpmx,ypmx,'raw\0')
Depending on the compiler it is treated differently so at some point we will have better solution.
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Saturday, July 3, 2010 1:51:57 PM GMT -06:00 US/Canada Central
Subject: [Nek5000-users] postx & movie
Hello all,
When trying to make a movie using "postx", I am running into the following sorts of errors (output to the terminal from "postx"):
convert: unable to open image `raw.rgb': No such file or directory.
In the directory that "postx" is running a "raw\0.rgb" appears but not a "raw.rgb".
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype) http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
More information about the Nek5000-users
