[Nek5000-users] Uservp and drag_calc routine
Sat Aug 14 21:44:49 CDT 2010
Interesting... I'll try this.
Paul
On Sat, 14 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Paul,
> Thanks for the reply.
> Yes. I set my wall as an obj through the same routine. It prints the value
> if param(30) is 0 but doesn't if param(30) is 1.
> I looked at the drag_calc() routine and found that it works for constant
> viscosity since param(2) is initialized to all the points while  torq_calc
> allows variable viscosity through visc array and so thought it might work
> with param(30)=1.
> Regards
> Shriram
