[Nek5000-users] Uservp and drag_calc routine
Sat Aug 14 21:14:05 CDT 2010
Paul,
Thanks for the reply.
Yes. I set my wall as an obj through the same routine. It prints the value
if param(30) is 0 but doesn't if param(30) is 1.
I looked at the drag_calc() routine and found that it works for constant
viscosity since param(2) is initialized to all the points while  torq_calc
allows variable viscosity through visc array and so thought it might work
with param(30)=1.
Regards
Shriram
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100814/a7c6b906/attachment.html>
