[Nek5000-users] Restart w/o saving over existing fld files?
Thu Aug 5 13:27:05 CDT 2010
Hi Hank,
Yes this is the exact issue, I will try it out. Thanks for the tip!
- Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, August 5, 2010 12:49:00 PM GMT -06:00 Guadalajara / Mexico City / Monterrey
Subject: Re: [Nek5000-users] Restart w/o saving over existing fld files?
Hi Michael,
You should be able to combine the restarts with a .visit file.
So:
% ls */*.nek3d
run1/f.nek3d
run2/f.nek3d
% ls */*.nek3d > both_runs.visit
% cat both_runs.visit
run1/f.nek3d
run2/f.nek3d
Then you can open both_runs.visit and it will append the time series together.
(Is this the problem you were encountering?)
Best,
Hank
On Thu, Aug 5, 2010 at 10:38 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hello,
Is there a way to restart without having Nek save new blah.f files over existing ones, perhaps tell it the number to start with?
Say I have run a simulation and have 50 fld files. I would like to restart from 50, but the next fld ideally should read 51, not 1. This makes it difficult to get into visit I have found when doing restarts (unless there is alternative trick to get around this?)
Thanks for any help with this ,
Michael
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
_______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100805/a3a482fb/attachment.html>
