[Nek5000-users] Residuals for post-processing
Sun Apr 25 14:21:29 CDT 2010
Hi Markus,
outpost simply provides a window towards generating
.fld files.
It's looking for 3 fields that will be interpreted as
components of the vector field (vx,vy,vz) -- but obviously
that field will contain only what is actually passed to it.
4th field is the pressure surrogate
5th field is the temperature surrogate.
It's important if using pn-pn-2 that the pressure field
look like a pressure field (the velocity and temp are pn,
pressure is pn-2).
Paul
On Sun, 25 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> uh-oh, I think I misread your first response - your suggestion was to
> include:
> call outpost(x,y,z,res,t,'res')
> call exitti('quit in gmres$',n)
> in gmres.f, not in usrchk ?
> What do x,v,and z stand for?
> Thanks,
> Markus
>> Hi Markus,
>> The issue here is that "res" is an argument passed into
>> the gmres solver and is not the stored value that is held
>> in GMRES, so a seg fault would be a natural failure.
>> The stored values are x,r,v,and z.
>> Paul
>>> Hi,
>>> this is what I added to usrchk:
>>>      include 'GMRES'
>>>      if (istep.gt.0) then
>>>       call outpost(vx,vy,vz,res,t,'res')
>>>      endif
>>> Unfortunately, this causes the code to crash whenever outpost is called:
>>>  120 1.00000E-06 8.11690E-04 5.58247E-01 1.45400E-03       1 Divergence
>>>          1    U-Pres gmres:      120   8.1169E-04   1.0000E-06 5.5825E-01
>>> 2.8286E+00   8.0148E+00
>>>           1  DNORM, DIVEX  0.35002708528548815 8.11690205515358640E-004
>>>          1   5.0000E-03  8.3137E+00 Fluid done
>>> filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0125 0.0500
>>> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.9875 0.9500
>>> ./nek: line 7: 11765 Segmentation fault      (core dumped) ./nek5000
>>> real    0m27.297s
>>> user    0m9.348s
>>> sys     0m1.124s
>>> I tried with pr instead of res, that works. Is it possible that res is not
>>> an array but a single number?
>>> Where are the residuals for velocity and passive scalars stored?
>>> I added the divergence procedure to the outflow, there is no back flow.
>>> The problem is not that the simulation blows up (at least for the time
>>> steps I am doing), it is that the pressure residuals don't fall below the
>>> specified limit when I increase lx1. This is for both PN/PN-2 and PN/PN
>>> and not a function of dt.
>>> Thanks,
>>> Markus
>>>> Hi Markus,
>>>> pressure residuals are in gmres
>>>> You could output them via:
>>>> where x,y,z,t are arrays of your choice and res
>>>> is the array you want to look at.
>>>> Nek will convert the res mesh to the velocity mesh
>>>> if needed.  I usually follow such a call with
>>>> because prepost() uses some scratch common blocks
>>>> that are potentially shared with the calling routine
>>>> (not in the case of gmres, I think...) -- so data might be corrupted
>>>> after such a call.   The idea of
>>>> prepost was to be called in between timesteps, when
>>>> such memory re-use would be admissable.   The alternative
>>>> would be to define your own storage in a common block,
>>>> save the residuals to this locale, then loop through
>>>> calls to outpost in userchk afterwards...  I've done
>>>> that in the past.
>>>> All this being said, I'm not 100% certain that the
>>>> iterative solvers is the place to look for the difficulty.
>>>> Most problems arise from spatial resolution issues...or
>>>> temporal stability problems.  The latter can be identified
>>>> by drastic reduction in dt.
>>>> What exactly is blowing up for you?
>>>> Paul
>>>> On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi,
>>>>> I'd like to save the residuals for the pressure iterations (PN/PN-2 as
>>>>> well as PN/PN) into a scalar variable (scalar 0, instead of temperature
>>>>> say) for each grid point in order to see where my solution diverges.
>>>>> Is there a way to add something to the .usr file to do that? I couldn't
>>>>> find the variable in the code and also wouldn't know how to save
>>>>> something from the lx2=lx1-2 grid onto the lx1 grid.
>>>>> Would this also be possible with the velocity residuals?
>>>>> Thanks,
>>>>> Markus
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> uuuu
>>>> c-----------------------------------------------------------------------
>>>>       subroutine uzawa_gmres(res,h1,h2,h2inv,intype,iter)
>>>> c     Solve the pressure equation by right-preconditioned c     GMRES
>>>> iteration.
>>>> c     intype =  0  (steady)
>>>> c     intype =  1  (explicit)
>>>> c     intype = -1  (implicit)
>>>>       include 'SIZE'
>>>>       include 'TOTAL'
>>>>       include 'GMRES'
>>>>       common  /ctolpr/ divex
>>>>       common  /cprint/ ifprint
>>>>       logical          ifprint
>>>>       real             res  (lx2*ly2*lz2*lelv)
>>>>       real             h1   (lx1,ly1,lz1,lelv)
>>>>       real             h2   (lx1,ly1,lz1,lelv)
>>>>       real             h2inv(lx1,ly1,lz1,lelv)
>>>>       common /scrmg/    wp (lx2,ly2,lz2,lelv)
>>>>       common /ctmp0/   wk1(lgmres),wk2(lgmres)
>>>>       common /cgmres1/ y(lgmres)
>>>>       real alpha, l, temp
>>>>       integer j,m
>>>> c
>>>>       logical iflag
>>>>       save    iflag
>>>>       data    iflag /.false./
>>>>       real    norm_fac
>>>>       save    norm_fac
>>>> c
>>>>       real*8 etime1,dnekclock
>>>> c
>>>>       if(.not.iflag) then
>>>>          iflag=.true.
>>>>          call uzawa_gmres_split0(ml,mu,bm2,bm2inv,nx2*ny2*nz2*nelv)
>>>>          norm_fac = 1./sqrt(volvm2)
>>>>       endif
>>>> c
>>>>       etime1 = dnekclock()
>>>>       etime_p = 0.
>>>>       divex = 0.
>>>>       iter  = 0
>>>>       m = lgmres
>>>> c
>>>>       call chktcg2(tolps,res,iconv)
>>>>       if (param(21).gt.0.and.tolps.gt.abs(param(21)))
>>>>      $   tolps = abs(param(21))
>>>> c     if (param(21).lt.0) tolps = abs(param(21))
>>>>       if (istep.eq.0) tolps = 1.e-4
>>>>       tolpss = tolps
>>>> c
>>>>       ntot2  = nx2*ny2*nz2*nelv
>>>> c
>>>>       iconv = 0
>>>>       call rzero(x,ntot2)
>>>>       do while(iconv.eq.0.and.iter.lt.100)
>>>>          if(iter.eq.0) then
>>>>                                                   !      -1
>>>>             call col3(r,ml,res,ntot2)             ! r = L  res
>>>> c           call copy(r,res,ntot2)
>>>>          else
>>>>             !update residual
>>>>             call copy(r,res,ntot2)                ! r = res
>>>>             call cdabdtp(w,x,h1,h2,h2inv,intype)  ! w = A x
>>>>             call add2s2(r,w,-1.,ntot2)            ! r = r - w
>>>>                                                   !      -1
>>>>             call col2(r,ml,ntot2)                 ! r = L   r
>>>>          endif
>>>>                                                   !            ______
>>>>          gamma(1) = sqrt(glsc2(r,r,ntot2))        ! gamma  = \/ (r,r)
>>>>                                                   !      1
>>>>          if(iter.eq.0) then
>>>>             div0 = gamma(1)*norm_fac
>>>>             if (param(21).lt.0) tolpss=abs(param(21))*div0
>>>>          endif
>>>>          !check for lucky convergence
>>>>          rnorm = 0.
>>>>          if(gamma(1) .eq. 0.) goto 9000
>>>>          temp = 1./gamma(1)
>>>>          call cmult2(v(1,1),r,temp,ntot2)         ! v  = r / gamma
>>>>                                                   !  1            1
>>>>          do j=1,m
>>>>             iter = iter+1
>>>>                                                   !       -1
>>>>             call col3(w,mu,v(1,j),ntot2)          ! w  = U   v
>>>>                                                   !           j
>>>>             etime2 = dnekclock()
>>>>             if(param(43).eq.1) then
>>>>                call uzprec(z(1,j),w,h1,h2,intype,wp)
>>>>             else                                  !       -1
>>>>                call hsmg_solve(z(1,j),w)          ! z  = M   w
>>>>             endif
>>>>             etime_p = etime_p + dnekclock()-etime2
>>>>             call cdabdtp(w,z(1,j),                ! w = A z
>>>>      $                   h1,h2,h2inv,intype)      !        j
>>>>                                                   !      -1
>>>>             call col2(w,ml,ntot2)                 ! w = L   w
>>>> c           !modified Gram-Schmidt
>>>> c           do i=1,j
>>>> c              h(i,j)=glsc2(w,v(1,i),ntot2)       ! h    = (w,v )
>>>> c                                                 !  i,j       i
>>>> c              call add2s2(w,v(1,i),-h(i,j),ntot2)! w = w - h    v
>>>> c           enddo                                 !          i,j  i
>>>> c           2-PASS GS, 1st pass:
>>>>             do i=1,j
>>>>                h(i,j)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
>>>>             enddo                                 !  i,j       i
>>>>             call gop(h(1,j),wk1,'+  ',j)          ! sum over P procs
>>>>             do i=1,j
>>>>             enddo                                 !          i,j  i
>>>> c           2-PASS GS, 2nd pass:
>>>> c
>>>> c           do i=1,j
>>>> c              wk1(i)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
>>>> c           enddo                                 !  i,j       i
>>>> c                                                 !
>>>> c           call gop(wk1,wk2,'+  ',j)             ! sum over P procs
>>>> c
>>>> c           do i=1,j
>>>> c              call add2s2(w,v(1,i),-wk1(i),ntot2)! w = w - h    v
>>>> c              h(i,j) = h(i,j) + wk1(i)           !          i,j  i
>>>> c           enddo
>>>>             !apply Givens rotations to new column
>>>>             do i=1,j-1
>>>>                temp = h(i,j)
>>>>                h(i  ,j)=  c(i)*temp + s(i)*h(i+1,j)
>>>>                h(i+1,j)= -s(i)*temp + c(i)*h(i+1,j)
>>>>             enddo
>>>>                                                   !            ______
>>>>             alpha = sqrt(glsc2(w,w,ntot2))        ! alpha =  \/ (w,w)
>>>>             rnorm = 0.
>>>>             if(alpha.eq.0.) goto 900  !converged
>>>>             l = sqrt(h(j,j)*h(j,j)+alpha*alpha)
>>>>             temp = 1./l
>>>>             c(j) = h(j,j) * temp
>>>>             s(j) = alpha  * temp
>>>>             h(j,j) = l
>>>>             gamma(j+1) = -s(j) * gamma(j)
>>>>             gamma(j)   =  c(j) * gamma(j)
>>>> c            call outmat(h,m,j,' h    ',j)
>>>>             rnorm = abs(gamma(j+1))*norm_fac
>>>>             ratio = rnorm/div0
>>>>             if (ifprint.and.nid.eq.0)
>>>>      $         write (6,66) iter,tolpss,rnorm,div0,ratio,istep
>>>>    66       format(i5,1p4e12.5,i8,' Divergence')
>>>> #ifndef TST_WSCAL
>>>>             if (rnorm .lt. tolpss) goto 900  !converged
>>>> #else
>>>>             if (iter.gt.param(151)-1) goto 900
>>>> #endif
>>>>             if (j.eq.m) goto 1000 !not converged, restart
>>>>             temp = 1./alpha
>>>>             call cmult2(v(1,j+1),w,temp,ntot2)   ! v    = w / alpha
>>>>                                                  !  j+1
>>>>          enddo
>>>>   900    iconv = 1
>>>>  1000    continue
>>>>          !back substitution
>>>>          !     -1
>>>>          !c = H   gamma
>>>>          do k=j,1,-1
>>>>             temp = gamma(k)
>>>>             do i=j,k+1,-1
>>>>                temp = temp - h(k,i)*c(i)
>>>>             enddo
>>>>             c(k) = temp/h(k,k)
>>>>          enddo
>>>>          !sum up Arnoldi vectors
>>>>          do i=1,j
>>>>             call add2s2(x,z(1,i),c(i),ntot2)     ! x = x + c  z
>>>>                                                  !          i  i
>>>>          enddo
>>>> c        if(iconv.eq.1) call dbg_write(x,nx2,ny2,nz2,nelv,'esol',3)
>>>>       enddo
>>>>  9000 continue
>>>> c
>>>>       divex = rnorm
>>>> c     iter = iter - 1
>>>> c
>>>> c     DIAGNOSTICS
>>>> c      call copy(w,x,ntot2)
>>>> c      if (ifvcor) then
>>>> c         xaver = glsc2(bm2,w,ntot2)/volvm2
>>>> c         call cadd(w,-xaver,ntot2)
>>>> c      endif
>>>> c      call copy(r,res,ntot2) !r = res
>>>> c      call cdabdtp(r,w,h1,h2,h2inv,intype)  ! r = A w
>>>> c      do i=1,ntot2
>>>> c         r(i) = res(i) - r(i)               ! r = res - r
>>>> c      enddo
>>>> c      call uzawa_gmres_temp(r,bm2inv,ntot2)
>>>> c                                               !            ______
>>>> c      gamma(1) = sqrt(glsc2(r,r,ntot2)/volvm2) ! gamma  = \/ (r,r) c !
>>>> 1
>>>> c      print *, 'GMRES end resid:',gamma(1)
>>>> c     END DIAGNOSTICS
>>>>       call copy(res,x,ntot2)
>>>> c
>>>>       if (ifvcor) then
>>>>          xaver = glsc2(bm2,res,ntot2)/volvm2
>>>>          call cadd(res,-xaver,ntot2)
>>>>       endif
>>>> c
>>>>       etime1 = dnekclock()-etime1
>>>>       if (nid.eq.0) write(6,9999) istep,iter,divex,tolpss,div0,etime_p,
>>>>      &                            etime1
>>>> c     call flush_hack
>>>>  9999 format(4X,I7,'    U-Pres gmres:   ',I6,1p5E13.4)
>>>> c
>>>> c
>>>>       return
>>>>       end
>>>>       subroutine uzawa_gmres_split0(l,u,b,binv,n)
>>>>       integer n
>>>>       real l(n),u(n),b(n),binv(n)
>>>>       integer i
>>>>       do i=1,n
>>>>          l(i)=sqrt(binv(i))
>>>>          u(i)=sqrt(b(i))
>>>>          if(abs(u(i)*l(i)-1.0).gt.1e-13) print *, i, u(i)*l(i)
>>>>       enddo
>>>>       return
>>>>       end
>>>>       subroutine uzawa_gmres_split(l,u,b,binv,n)
>>>>       integer n
>>>>       integer i
>>>>       do i=1,n
>>>> c        l(i)=sqrt(binv(i))
>>>> c        u(i)=sqrt(b(i))
>>>> c        u(i)=sqrt(b(i))
>>>> c        l(i)=1./u(i)
>>>>          l(i)=1.
>>>>          u(i)=1./l(i)
>>>> c        if(abs(u(i)*l(i)-1.0).gt.1e-13)write(6,*) i,u(i)*l(i),' gmr_sp'
>>>>       enddo
>>>>       return
>>>>       end
>>>>       subroutine uzawa_gmres_temp(a,b,n)
>>>>       integer n
>>>>       real a(n),b(n)
>>>>       integer i
>>>>       do i=1,n
>>>>          a(i)=sqrt(b(i))*a(i)
>>>>       enddo
>>>>       return
>>>>       end
>>>>       subroutine ax(w,x,h1,h2,n)
>>>>       include 'SIZE'
>>>>       include 'TOTAL'
>>>> c
>>>> c     w = A*x for pressure iteration
>>>> c
>>>>       integer n
>>>>       real w(n),x(n),h1(n),h2(n)
>>>>       imsh = 1
>>>>       isd  = 1
>>>>       call axhelm (w,x,h1,h2,imsh,isd)
>>>>       call dssum  (w,nx1,ny1,nz1)
>>>>       call col2   (w,pmask,n)
>>>>       return
>>>>       end
>>>>       subroutine hmh_gmres(res,h1,h2,wt,iter)
>>>> c     Solve the Helmholtz equation by right-preconditioned c     GMRES
>>>> iteration.
>>>>       include 'SIZE'
>>>>       include 'TOTAL'
>>>>       include 'FDMH1'
>>>>       include 'GMRES'
>>>>       logical          ifprint
>>>>       real             res  (lx1*ly1*lz1*lelv)
>>>>       real             wt   (lx1,ly1,lz1,lelv)
>>>>       common /scrcg/ d(lx1*ly1*lz1*lelv),wk(lx1*ly1*lz1*lelv)
>>>>       real alpha, l, temp
>>>>       integer j,m
>>>>       logical iflag
>>>>       save    iflag
>>>>       real    norm_fac
>>>>       save    norm_fac
>>>>       n = nx1*ny1*nz1*nelv
>>>>       etime_p = 0.
>>>>       divex = 0.
>>>>       iter  = 0
>>>>       m     = lgmres
>>>>       if(.not.iflag) then
>>>>          iflag=.true.
>>>>          call uzawa_gmres_split(ml,mu,bm1,binvm1,nx1*ny1*nz1*nelv)
>>>>          norm_fac = 1./sqrt(volvm1)
>>>>       endif
>>>>       call set_fdm_prec_h1b(d,h1,h2,nelv)
>>>>       if (ifvcor) smean = -1./glsum(vmult,n)
>>>>       call chktcg1(tolps,res,h1,h2,pmask,vmult,1,1)
>>>>       tolpss = tolps
>>>> c
>>>>       iconv = 0
>>>>       call rzero(x,n)
>>>>       do while(iconv.eq.0.and.iter.lt.500)
>>>>          if(iter.eq.0) then               !      -1
>>>>             call col3(r,ml,res,n)         ! r = L  res
>>>> c           call copy(r,res,n)
>>>>          else
>>>>             !update residual
>>>>             call copy  (r,res,n)                  ! r = res
>>>>             call ax    (w,x,h1,h2,n)              ! w = A x
>>>>             call add2s2(r,w,-1.,n)                ! r = r - w
>>>>                                                   !      -1
>>>>             call col2(r,ml,n)                     ! r = L   r
>>>>          endif
>>>>                                                   !            ______
>>>>          gamma(1) = sqrt(glsc3(r,r,wt,n))         ! gamma  = \/ (r,r)
>>>>                                                   !      1
>>>>          if(iter.eq.0) then
>>>>          endif
>>>>          rnorm = 0.
>>>>          temp = 1./gamma(1)
>>>>          call cmult2(v(1,1),r,temp,n)             ! v  = r / gamma
>>>>                                                   !  1            1
>>>>          do j=1,m
>>>>             iter = iter+1
>>>>                                                   !       -1
>>>>             call col3(w,mu,v(1,j),n)              ! w  = U   v
>>>>                                                   !           j
>>>> c . . . . . Overlapping Schwarz + coarse-grid . . . . . . .
>>>>             kfldfdm = ndim+1
>>>>             call fdm_h1
>>>>      $           (z(1,j),w,d,pmask,vmult,nelv,ktype(1,1,kfldfdm),wk)
>>>>             call crs_solve_h1 (wk,w) c           call
>>>>                                                   !  j
>>>>             call add2         (z(1,j),wk,n)
>>>>             if (ifvcor) then
>>>>                rmean = smean*glsc2(z(1,j),vmult,n)
>>>>                call cadd(z(1,j),rmean,n)
>>>>             endif
>>>> c . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>>>>             call ax  (w,z(1,j),h1,h2,n)           ! w = A z
>>>>                                                   !        j
>>>>                                                   !      -1
>>>>             call col2(w,ml,n)                     ! w = L   w
>>>> c           do i=1,j
>>>> c              h(i,j)=glsc3(w,v(1,i),wt,n)        ! h    = (w,v )
>>>> c                                                 !  i,j       i
>>>> c              call add2s2(w,v(1,i),-h(i,j),n)    ! w = w - h    v
>>>> c           enddo                                 !          i,j  i
>>>>             do i=1,j
>>>>                h(i,j)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
>>>>             enddo                                 !  i,j       i
>>>>             do i=1,j
>>>>             enddo                                 !          i,j  i
>>>> c
>>>> c           do i=1,j
>>>> c              wk1(i)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
>>>> c           enddo                                 !  i,j       i
>>>> c                                                 !
>>>> c
>>>> c           do i=1,j
>>>> c              call add2s2(w,v(1,i),-wk1(i),n)    ! w = w - h    v
>>>> c           enddo
>>>>             do i=1,j-1
>>>>                temp = h(i,j)
>>>>             enddo
>>>>                                                  !            ______
>>>>             alpha = sqrt(glsc3(w,w,wt,n))        ! alpha =  \/ (w,w)
>>>>             rnorm = 0.
>>>>             temp = 1./l
>>>>             s(j) = alpha  * temp
>>>>             h(j,j) = l
>>>>             ratio = rnorm/div0
>>>> #ifndef TST_WSCAL
>>>> #else
>>>> #endif
>>>>             temp = 1./alpha
>>>>             call cmult2(v(1,j+1),w,temp,n)   ! v    = w / alpha
>>>>                                              !  j+1
>>>>          enddo
>>>>   900    iconv = 1
>>>>  1000    continue
>>>>          !back substitution
>>>>          !     -1
>>>>          !c = H   gamma
>>>>          do k=j,1,-1
>>>>             temp = gamma(k)
>>>>             do i=j,k+1,-1
>>>>             enddo
>>>>             c(k) = temp/h(k,k)
>>>>          enddo
>>>>          do i=1,j
>>>>             call add2s2(x,z(1,i),c(i),n)     ! x = x + c  z
>>>>          enddo                               !          i  i
>>>> c        if(iconv.eq.1) call dbg_write(x,nx1,ny1,nz1,nelv,'esol',3)
>>>>       enddo
>>>>  9000 continue
>>>> c
>>>>       divex = rnorm
>>>>       call copy(res,x,n)
>>>> c
>>>>       if (ifvcor) then
>>>>          xaver = glsc2(bm1,res,n)/volvm1
>>>>          call cadd(res,-xaver,n)
>>>>       endif
>>>> c
>>>>      &                            etime1
>>>> c     call flush_hack
>>>>  9999 format(4X,I7,'    PRES gmres:   ',I6,1p5E13.4)
>>>>       return
>>>>       end
