[Nek5000-users] Nekmerge question
Thu Apr 22 10:25:44 CDT 2010
Hi Jean-Christophe,
It should inherit the bcs from the originating meshes
and it will replace any bcs on shared interfaces with E-E
automatically.
Very important that the meshes you are merging are compatible
with conforming interfaces and no domain overlap --- the
merge code does not check for these conditions.
Paul
On Thu, 22 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Now that I can use pretex, I still have a few questions.
> Everything is going as it should (according to your answer Paul) until I
> reach the boundary conditions stage. Instead of getting:
>       1 ACCEPT B.C.'s
>       2 REVIEW/MODIFY
> I get the following:
>        *** MIDWAY BREAK MENU ***
>       ABORT to write build data to file and exit
>       SET B.C'S to continue
>              1 SET BCs                               2 ABORT
> As I wanna join the two meshes, I assume that the correct boundary conditions
> should be E (element) in the .box files. Nevertheless, such BC does not
> appear when choosing SET BCs. Here is what I get:
> *** BOUNDARY CONDITION MENU ***
> Begin Inputting Fluid Boundary Conditions
> B.C.>        74         1
>      1 PERIODIC-AUTO                 2 PERIODIC                      3 WALL
> 4 VELOCITY                      5 OUTFLOW                       6 OUTFLOW/N
> 7 VELOCITY (LOCAL)              8 SYMMETRY                      9 MOVING WALL
> 10 MELTING FRONT                11 SET ENTIRE LEVEL             12 ZOOM
> I suppose that this problem might perhaps come from the fact that I do not
> have the same number of faces on the joining borders of each mesh, or
> something more or less the same. Is there anything more-or-less easy I could
> do, or do I have to built the square mesh so that each edge/face for the two
> joining borders are the same ?
> Regards,
> Jean-Christophe
> PS: Attached are the .rea and .box files I have used again.
