[Nek5000-users] Nekmerge question
Thu Apr 22 08:26:55 CDT 2010
Ok I think I know a way to fix the Intel compiler problem.
To compile prenek (prex) you need to enable the BIGMEM support so you have to use at least the medium memory model. However the Intel compilers wants you to link all Intel-Libs dynamically if you use another memory model than small.
Just set F77= "ifort -shared-intel" and it should work!
hth,
Stefan
On Apr 22, 2010, at 3:12 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Yes, it seems like we're having a problem with the Intel compiler. Let me check into that.
> Stefan
> On Apr 22, 2010, at 2:56 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Sure I did.
>> It seems that when BIGMEM="true" I get errors only when using ifort. Things get different when using gfortran.
>> JC
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
