[Nek5000-users] *.fld files to ...
Mon Apr 19 11:46:45 CDT 2010
I first need to rewrite the part discovering the mesh topology. I don't like the way it's coded now. I
I'll send you something hopefully by the end of this week.
Stefan
On Apr 19, 2010, at 6:41 PM, nek5000-users at lists.mcs.anl.gov wrote:
> On Mon, 2010-04-19 at 18:33 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Frank,
>> If you're interested in my old converter we could work together to improve it. Just led me know.
> Very interested.  If you dig it up I'll take a look at it immediately.
> Cheers,
> Frank
>> Stefan
>> On Apr 19, 2010, at 6:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello Stefan,
>>> Actually I would like to do that.  I am quite familiar with I/O and
>>> Tecplot and could make a writer that outputs their binary format files.
>>> This could be done two ways, outputting directly from NEK to Tecplot
>>> format files (and therefore not using the *.fld files for I/O) or
>>> something that takes the *.fld files and creates Tecplot format files.
>>> I tend to think the second is the best method as the issue of parallel
>>> I/O is sidestepped.  What is your opinion on this?
>>> Cheers,
>>> Frank
>>> On Mon, 2010-04-19 at 18:02 +0200, nek5000-users at lists.mcs.anl.gov
>>> wrote:
>>>> Yes you're right the export capabilities to TecPlot are quite limited (no multizone support, etc.).
>>>> If you know the data layout of NEK it's quite easy write your own convert.
>>>> We did that for TecPlot some time ago.
>>>> Stefan
>>>> On Apr 19, 2010, at 5:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Stefan,
>>>>> Thanks.  I had tried that.  This translator appears to be a fairly rough
>>>>> attempt to output data in Tecplot's format.  It at times writes out
>>>>> files that Tecplot cannot read.  In addition, if dealing with temporal
>>>>> data, there appears to be no way to write out the data at each time step
>>>>> to a single Tecplot file.  Therefore, one would need to do this
>>>>> (exporting through the menus) for every file at every time step.
>>>>> Cheers,
>>>>> Frank
>>>>> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
>>>>> wrote:
>>>>>> Frank,
>>>>>> read your data into VisIt and use the export option.
>>>>>> I don't recall exactly what output formats they support but there are quite a few.
>>>>>> Stefan
>>>>>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hello all,
>>>>>>> Does anyone know of a way to translate *.fld files to a different format
>>>>>>> (perhaps such as HDF, CGNS, Plot3D etc.)?
>>>>>>> Cheers,
>>>>>>> Frank
>>>>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>>>>> Technische Universität Wien (Technical University of Vienna)
>>>>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>>>>> Mechanics and Heat Transfer)
>>>>>>> Resselgasse 3
>>>>>>> 1040 Wien
>>>>>>> Tel: +4315880132232
>>>>>>> Fax: +4315880132299
>>>>>>> Cell:+436765203470
>>>>>>> fmuldoo (skype)
>>>>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>>>>> _______________________________________________
>>>>>>> Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>> Resselgasse 3
>>>>> 1040 Wien
>>>>> Tel: +4315880132232
>>>>> Fax: +4315880132299
>>>>> Cell:+436765203470
>>>>> fmuldoo (skype)
>>> Resselgasse 3
>>> 1040 Wien
>>> Tel: +4315880132232
>>> Fax: +4315880132299
>>> Cell:+436765203470
>>> fmuldoo (skype)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
