[Nek5000-users] *.fld files to ...
Mon Apr 19 11:41:48 CDT 2010
On Mon, 2010-04-19 at 18:33 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> Frank,
> If you're interested in my old converter we could work together to improve it. Just led me know.
Very interested.  If you dig it up I'll take a look at it immediately.
Cheers,
Frank
> Stefan
> On Apr 19, 2010, at 6:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello Stefan,
> > Actually I would like to do that.  I am quite familiar with I/O and
> > Tecplot and could make a writer that outputs their binary format files.
> > This could be done two ways, outputting directly from NEK to Tecplot
> > format files (and therefore not using the *.fld files for I/O) or
> > something that takes the *.fld files and creates Tecplot format files.
> > I tend to think the second is the best method as the issue of parallel
> > I/O is sidestepped.  What is your opinion on this?
> > Cheers,
> > Frank
> > On Mon, 2010-04-19 at 18:02 +0200, nek5000-users at lists.mcs.anl.gov
> > wrote:
> >> Yes you're right the export capabilities to TecPlot are quite limited (no multizone support, etc.).
> >> If you know the data layout of NEK it's quite easy write your own convert.
> >> We did that for TecPlot some time ago.
> >> Stefan
> >> On Apr 19, 2010, at 5:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> Hi Stefan,
> >>> Thanks.  I had tried that.  This translator appears to be a fairly rough
> >>> attempt to output data in Tecplot's format.  It at times writes out
> >>> files that Tecplot cannot read.  In addition, if dealing with temporal
> >>> data, there appears to be no way to write out the data at each time step
> >>> to a single Tecplot file.  Therefore, one would need to do this
> >>> (exporting through the menus) for every file at every time step.
> >>> Cheers,
> >>> Frank
> >>> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
> >>> wrote:
> >>>> Frank,
> >>>> read your data into VisIt and use the export option.
> >>>> I don't recall exactly what output formats they support but there are quite a few.
> >>>> Stefan
> >>>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>>>> Hello all,
> >>>>> Does anyone know of a way to translate *.fld files to a different format
> >>>>> (perhaps such as HDF, CGNS, Plot3D etc.)?
> >>>>> Cheers,
> >>>>> Frank
> >>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> >>>>> Technische Universität Wien (Technical University of Vienna)
> >>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> >>>>> Mechanics and Heat Transfer)
> >>>>> Resselgasse 3
> >>>>> 1040 Wien
> >>>>> Tel: +4315880132232
> >>>>> Fax: +4315880132299
> >>>>> Cell:+436765203470
> >>>>> fmuldoo (skype)
> >>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> >>>>> _______________________________________________
> >>>>> Nek5000-users mailing list
> >>>>> Nek5000-users at lists.mcs.anl.gov
> >>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> >>> Resselgasse 3
> >>> 1040 Wien
> >>> Tel: +4315880132232
> >>> Fax: +4315880132299
> >>> Cell:+436765203470
> >>> fmuldoo (skype)
> > Resselgasse 3
> > 1040 Wien
> > Tel: +4315880132232
> > Fax: +4315880132299
> > Cell:+436765203470
> > fmuldoo (skype)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
