[Nek5000-users] *.fld files to ...
Mon Apr 19 11:29:46 CDT 2010
Frank,
why do you want to use TecPlot?
I know sometime it's just because you don't want to dig into another tool.
However if there are other good reasons I am sure Hank will be quite interested to improve VisIt.
Stefan
On Apr 19, 2010, at 6:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Yes, I think a convert is the way to go.
> I will release at some point my old TecPlot convert however I need to fix a few things first. Unfortunately I am quite busy these days so it will take some time.
> Stefan
> On Apr 19, 2010, at 6:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello Stefan,
>> Actually I would like to do that.  I am quite familiar with I/O and
>> Tecplot and could make a writer that outputs their binary format files.
>> This could be done two ways, outputting directly from NEK to Tecplot
>> format files (and therefore not using the *.fld files for I/O) or
>> something that takes the *.fld files and creates Tecplot format files.
>> I tend to think the second is the best method as the issue of parallel
>> I/O is sidestepped.  What is your opinion on this?
>> Cheers,
>> Frank
>> On Mon, 2010-04-19 at 18:02 +0200, nek5000-users at lists.mcs.anl.gov
>> wrote:
>>> Yes you're right the export capabilities to TecPlot are quite limited (no multizone support, etc.).
>>> If you know the data layout of NEK it's quite easy write your own convert.
>>> We did that for TecPlot some time ago.
>>> Stefan
>>> On Apr 19, 2010, at 5:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Stefan,
>>>> Thanks.  I had tried that.  This translator appears to be a fairly rough
>>>> attempt to output data in Tecplot's format.  It at times writes out
>>>> files that Tecplot cannot read.  In addition, if dealing with temporal
>>>> data, there appears to be no way to write out the data at each time step
>>>> to a single Tecplot file.  Therefore, one would need to do this
>>>> (exporting through the menus) for every file at every time step.
>>>> Cheers,
>>>> Frank
>>>> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
>>>> wrote:
>>>>> Frank,
>>>>> read your data into VisIt and use the export option.
>>>>> I don't recall exactly what output formats they support but there are quite a few.
>>>>> Stefan
>>>>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hello all,
>>>>>> Does anyone know of a way to translate *.fld files to a different format
>>>>>> (perhaps such as HDF, CGNS, Plot3D etc.)?
>>>>>> Cheers,
>>>>>> Frank
>>>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>>>> Technische Universität Wien (Technical University of Vienna)
>>>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>>>> Mechanics and Heat Transfer)
>>>>>> Resselgasse 3
>>>>>> 1040 Wien
>>>>>> Tel: +4315880132232
>>>>>> Fax: +4315880132299
>>>>>> Cell:+436765203470
>>>>>> fmuldoo (skype)
>>>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Resselgasse 3
>>>> 1040 Wien
>>>> Tel: +4315880132232
>>>> Fax: +4315880132299
>>>> Cell:+436765203470
>>>> fmuldoo (skype)
>> Resselgasse 3
>> 1040 Wien
>> Tel: +4315880132232
>> Fax: +4315880132299
>> Cell:+436765203470
>> fmuldoo (skype)
