[Nek5000-users] Makenek compilation problems
Tue Apr 13 07:49:47 CDT 2010
Hi Jean-Christophe,
first of all welcome to NEK world :)
I think your Fortran MPI-wrapper (mpif77) is using g77 which we do not support!
Any chance to switch to another supported compiler (see here: https://nek5000.mcs.anl.gov/index.php/UG).
Stefan
On Apr 13, 2010, at 2:33 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
> I am a french student currently doing my final year internship, and a brand new user of Nek 5k.
> So far, I am not yet accustomed parallel calculations, and that is where my problems might probably come from within the following weeks.
> I use two computers at the lab. On my own computer, when I run ./makenek blah with the following options:/*
>   /*IFMPI=true*/
>   /*F77="mpif77"*/
>   /*CC="mpicc"*/
> I have absolutely no problem, the code is compiled. But when I run ./makenek blah with these options on the other one (plus */G="-g"/*), it doesn't work. I get the followinng warning message:
>   */WARNING: Cannot detect compiler specific flags/*
>   */      echo  - to promote REAL to 8 bytes/*
>   */      echo  - to invoke preprocessor first/*
>   */Please edit the makefile and specify the requested compiler flags
>   in the P variable!/*
> I do not really know which flags I should use... Attached is the corresponding compiler.out file if needed.
> It would be greatly appreciated if anyone could give me a hint on what to do.
> Regards,
> Jean-Christophe
> mpif77 -c -g -O0 -DMPI -DLONGINT8 -I/home/loiseau/nek5_svn/trunk/nek -I/home/loiseau/nek5_svn/examples/pipe  /home/loiseau/nek5_svn/trunk/nek/drive.f
> mpif77 -c -g -O0 -DMPI -DLONGINT8 -I/home/loiseau/nek5_svn/trunk/nek -I/home/loiseau/nek5_svn/examples/pipe  /home/loiseau/nek5_svn/trunk/nek/drive1.f
> mpif77 -c -g -O0 -DMPI -DLONGINT8 -I/home/loiseau/nek5_svn/trunk/nek -I/home/loiseau/nek5_svn/examples/pipe  /home/loiseau/nek5_svn/trunk/nek/drive2.f
> mpif77 -c -g -O0 -DMPI -DLONGINT8 -I/home/loiseau/nek5_svn/trunk/nek -I/home/loiseau/nek5_svn/examples/pipe /home/loiseau/nek5_svn/trunk/nek/plan4.f
> mpif77 -c -g -O0 -DMPI -DLONGINT8 -I/home/loiseau/nek5_svn/trunk/nek -I/home/loiseau/nek5_svn/examples/pipe /home/loiseau/nek5_svn/trunk/nek/bdry.f
> SOLN: In subroutine `plan4':
> SOLN:14:
>         parameter (lorder2 = max(1,lorder-2) )
> Invalid declaration of or reference to symbol `max' at (^) [initially seen at (^)]
> SOLN: In subroutine `nek_init':
> SOLN:14:
> SOLN:63:
>        $               , PMLAG  (LBX2*LBY2*LBZ2*LBELV,LORDER2)
> Invalid declaration of or reference to symbol `pmlag' at (^) [initially seen at (^)]
> SOLN:67:
>        $               , PRLAG  (LX2,LY2,LZ2,LELV,LORDER2)
> Invalid declaration of or reference to symbol `prlag' at (^) [initially seen at (^)]
> SOLN:99:
>        $              , PRLAGP (LPX2*LPY2*LPZ2*LPELV,LORDER2,lpert)
> Invalid declaration of or reference to symbol `prlagp' at (^) [initially seen at (^)]
> SOLN:63:
> SOLN:67:
> SOLN:99:
> In file included from SOLN:350228800,
>                 from /home/loiseau/nek5_svn/trunk/nek/plan4.f:16:
> In file included from /home/loiseau/nek5_svn/trunk/nek/plan4.f:20:
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:57: erreur: undefined or invalid # directive
> SOLN: In subroutine `initdat':
> SOLN:14:
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:62: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:75: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:77: erreur: undefined or invalid # directive
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `crespsp':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/drive1.f: In subroutine `nek_solve':
> In file included from SOLN:155702064,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive1.f:6:
> In file included from /home/loiseau/nek5_svn/trunk/nek/drive1.f:178:
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:197: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:199: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:200: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:203: erreur: undefined or invalid # directive
> SOLN: In subroutine `nek_advance':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:20: warning:
>         COMMON /SCRNS/ RES1  (LX1,LY1,LZ1,LELV)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:197: (continued):
>         COMMON /SCRNS/ TA1   (LX1*LY1*LZ1,LELV)
>                 2
> Common block `scrns' is 2230400 bytes in length at (1) but 2125440 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> SOLN: In subroutine `cresvsp':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/drive1.f: In subroutine `nek_end':
> In file included from SOLN:156164560,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive1.f:219:
> In file included from /home/loiseau/nek5_svn/trunk/nek/drive1.f:283:
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:293: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/drive1.f:298: erreur: undefined or invalid # directive
> SOLN: In subroutine `bcmask':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> make: *** [drive1.o] Erreur 1
> make: *** Attente des tâches non terminées....
> SOLN: In subroutine `fluid':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `bcdirvc':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `op_curl':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `bcdirsc':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `rstartc':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `split_vis':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN: In subroutine `bcneusc':
> SOLN:14:
> SOLN:99:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `redo_split_vis':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `time00':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `nekasgn':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `bcneutr':
> SOLN:14:
> SOLN: In subroutine `v_extrap':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f: Outside of any program unit:
> SOLN:99:
> SOLN:63:
> SOLN:67:
> In file included from SOLN:462261632,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive2.f:42:
> In file included from SOLN:461742752,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive2.f:731:
> In file included from SOLN:463895248,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive2.f:900:
> In file included from SOLN:465002448,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive2.f:1096:
> In file included from /home/loiseau/nek5_svn/trunk/nek/drive2.f:1098:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1164: erreur: undefined or invalid # directive
> SOLN:99:
> SOLN: In subroutine `timeout':
> SOLN:14:
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:783: warning:
>         call add3s2(vext(1,2),vy,vylag,ab0,ab1,ntot)
> Array element value at (^) out of defined range
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:784: warning:
>         if(if3d) call add3s2(vext(1,3),vz,vzlag,ab0,ab1,ntot)
> SOLN:63:
> SOLN:67:
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:788: warning:
>           call add2s2(vext(1,2),vylag(1,1,1,1,2),ab2,ntot)
> /home/loiseau/nek5_svn/trunk/nek/plan4.f:789: warning:
>           if(if3d) call add2s2(vext(1,3),vzlag(1,1,1,1,2),ab2,ntot)
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:712: warning:
>         COMMON /SCRSF/ TMP(LX1,LY1,LZ1,LELT)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1207: (continued):
>         COMMON /SCRSF/ TRX(LX1,LY1,LZ1)
>                 2
> Common block `scrsf' is 1062720 bytes in length at (1) but 2592 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> make: *** [plan4.o] Erreur 1
> In file included from SOLN:464987808,
>                 from TOTAL:11,
>                 from /home/loiseau/nek5_svn/trunk/nek/drive2.f:1168:
> In file included from /home/loiseau/nek5_svn/trunk/nek/drive2.f:1170:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1302: erreur: undefined or invalid # directive
> /home/loiseau/nek5_svn/trunk/nek/bdry.f: In subroutine `trstax':
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1353: warning:
>         COMMON /CTMP1/ A1X(LX1),A1Y(LX1),STX(LX1),STY(LX1)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1418: (continued):
>         COMMON /CTMP1/ A1X(LX1),A1Y(LX1),A2X(LX1),A2Y(LX1)
>                 2
> Common block `ctmp1' is 96 bytes in length at (1) but 168 bytes at (2)
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1210: warning:
>         COMMON /CTMP0/ STC(LX1,LY1,LZ1)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1420: (continued):
>         COMMON /CTMP0/ XFM1(LX1),YFM1(LX1),T1XF(LX1),T1YF(LX1)
>                 2
> Common block `ctmp0' is 864 bytes in length at (1) but 96 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> SOLN: In subroutine `ctang2d':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f: In subroutine `opcount':
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1542: warning:
>               call csend(mtag,s,1,i,0)    ! send handshake
>                    1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1591: (continued):
>                 call csend(i,idum,4,i,0)
>                      2
> Argument #2 of `csend' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1545: warning:
>               call crecv(i,w,m)
>                    1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1592: (continued):
>                 call crecv(i,ddcount,wdsize)
>                      2
> Argument #2 of `crecv' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
>               call crecv(i,w,m)
>                    1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1596: (continued):
>               call crecv (nid,idum,4)
>                    2
>                    1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1597: (continued):
>               call csend (nid,dcount,wdsize,0,0)
>                    2
> SOLN: In subroutine `dofcnt':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/bdry.f: In subroutine `trst3d':
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1598: (continued):
>         COMMON /CTMP0/  XFM1(LX1,LY1),YFM1(LX1,LY1),ZFM1(LX1,LY1)
>                 2
> Common block `ctmp0' is 864 bytes in length at (1) but 432 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1599: (continued):
>         COMMON /CTMP1/  DRM1(LX1,LX1),DRTM1(LX1,LY1)
>                 2
> Common block `ctmp1' is 168 bytes in length at (1) but 720 bytes at (2)
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:576: warning:
>         COMMON /SCRMG/ TMQ1(LX1,LY1,LZ1,LELV)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1602: (continued):
>         COMMON /SCRMG/  XRM1(LX1,LY1),YRM1(LX1,LY1),ZRM1(LX1,LY1)
>                 2
> Common block `scrmg' is 1062720 bytes in length at (1) but 864 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:573: warning:
>         COMMON /SCRUZ/ TMP1(LX1,LY1,LZ1,LELV)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1604: (continued):
>         COMMON /SCRUZ/  S1X(LX1,LY1),S1Y(LX1,LY1),S1Z(LX1,LY1)
>                 2
> Common block `scruz' is 1062720 bytes in length at (1) but 864 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> SOLN: In subroutine `setshl':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1850: (continued):
>         COMMON /SCRMG/ V1(LX1,LY1,LZ1,LELV)
>                 2
> Common block `scrmg' is 1062720 bytes in length at (1) but 1416960 bytes at (2)
> SOLN: In subroutine `vol_flow':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `chkzvn':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `check_cyclic':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> SOLN: In subroutine `compute_vol_soln':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
>                 1
> /home/loiseau/nek5_svn/trunk/nek/bdry.f:1992: (continued):
>         common /scrmg/ v1(lx1,ly1,lz1,lelt)
>                 2
> Common block `scrmg' is 1416960 bytes in length at (1) but 1062720 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> make: *** [bdry.o] Erreur 1
> SOLN: In subroutine `plan2_vol':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:1681: warning:
>         COMMON /SCRNS/ WORK(LCTMP1)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:2042: (continued):
>         COMMON /SCRNS/ RESV1 (LX1,LY1,LZ1,LELV)
>                 2
> Common block `scrns' is 1416960 bytes in length at (1) but 1167680 bytes at (2)
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
>                 1
>                 2
> SOLN: In subroutine `plan3_vol':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
>                 1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:2155: (continued):
>         COMMON /SCRNS/ rw1   (LX1,LY1,LZ1,LELV)
>                 2
> Common block `scrns' is 1416960 bytes in length at (1) but 2230400 bytes at (2)
> SOLN: In subroutine `a_dmp':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
>                 1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:2225: (continued):
>         COMMON /SCRNS/ w(LX1,LY1,LZ1,LELT)
>                 2
> Common block `scrns' is 2230400 bytes in length at (1) but 354240 bytes at (2)
>                 1
>                 2
>                 1
>                 2
> SOLN: In subroutine `reset_prop':
> SOLN:14:
> SOLN:63:
> SOLN:67:
> SOLN:99:
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:470: warning:
>         COMMON /SCRUZ/ XM3 (LX3,LY3,LZ3,LELT)
>                 1
> /home/loiseau/nek5_svn/trunk/nek/drive2.f:2380: (continued):
>         COMMON /SCRUZ/ TA(LX1,LY1,LZ1,LELT)
>                 2
> Common block `scruz' is 1062720 bytes in length at (1) but 354240 bytes at (2)
>                 1
>                 2
>                 1
>                 2
> make: *** [drive2.o] Erreur 1
> Nek5000-users mailing list
