[Nek5000-users] PN/PN and usrdiv
Fri Apr 9 08:05:14 CDT 2010
I have not used this feature for a while but usrdiv is used in plan4().
--- snip plan4.f ---
40       ! add user defined divergence to qtl
41       call col3 (h1,usrdiv,bm1,ntot1)
42       call add2 (qtl,h1,ntot1)
--- snip plan4.f
Stefan
On Apr 9, 2010, at 1:49 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> since I switched the pressure scheme from P_N/P_N-2 to PN/PN, as recommended by an earlier email, I have divergence trouble (simulation crashes) at the outflow, were a stabilization technique as in examples "peris" and "jet" is in place (adding divergence via usrdiv).
> I spent a long time trying to fix this (several test runs with increased outflow normal element length, increased divergence magnitude, mesh deformation to nozzle shape, which avoids crashing but has an adverse effect on the upstream flow,...) but I am becoming suspicious that usrdiv is just not used in PN/PN.
> Is that true? If so, how to fix it?
> Thanks,
> Markus
> Nek5000-users mailing list
