[Nek5000-users] PN/PN and usrdiv
Fri Apr 9 06:49:23 CDT 2010
since I switched the pressure scheme from P_N/P_N-2 to PN/PN, as
recommended by an earlier email, I have divergence trouble (simulation
crashes) at the outflow, were a stabilization technique as in examples
"peris" and "jet" is in place (adding divergence via usrdiv).
I spent a long time trying to fix this (several test runs with increased
outflow normal element length, increased divergence magnitude, mesh
deformation to nozzle shape, which avoids crashing but has an adverse
effect on the upstream flow,...) but I am becoming suspicious that
usrdiv is just not used in PN/PN.
Is that true? If so, how to fix it?
Markus
