[Nek5000-users] question about comilers
Fri Apr 9 03:49:21 CDT 2010
Also, I am not sure if g95/gcc will work out of the box. So far we only support gfortran/gcc.
Stefan
On Apr 9, 2010, at 10:36 AM, nek5000-users at lists.mcs.anl.gov wrote:
> check the 'How to compile' section on the wiki to get a list of supported compilers.
> http://nek5000.mcs.anl.gov/index.php/UG
> Stefan
> On Apr 9, 2010, at 10:25 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Mark,
>> g95 + gcc I think is fine... cc'g the users list
>> I believe the builds should just go through w/ the current
>> repo version of the code.
>> Paul
>> On Fri, 9 Apr 2010, Mark Paul wrote:
>>> Hi Paul,
>>> Can you recommend a free set of compilers we can use on mac os x
>>> snow leopard and for linux to run nekton, postx, and prex? We have
>>> used pgi in the past but it is getting too pricey and always seems
>>> to need an expensive upgrade to be supported on current os distributions etc.
>>> This would just be for small jobs and post-processing. I was going
>>> to try gcc and gfortran but wanted to get your thoughts on this
>>> before hacking around too much.
>>> Thanks,
>>> Mark
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
