[Nek5000-users] question about comilers
Fri Apr 9 03:36:55 CDT 2010
check the 'How to compile' section on the wiki to get a list of supported compilers.
http://nek5000.mcs.anl.gov/index.php/UG
Stefan
On Apr 9, 2010, at 10:25 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Mark,
> g95 + gcc I think is fine... cc'g the users list
> I believe the builds should just go through w/ the current
> repo version of the code.
> Paul
> On Fri, 9 Apr 2010, Mark Paul wrote:
>> Hi Paul,
>> Can you recommend a free set of compilers we can use on mac os x
>> snow leopard and for linux to run nekton, postx, and prex? We have
>> used pgi in the past but it is getting too pricey and always seems
>> to need an expensive upgrade to be supported on current os distributions etc.
>> This would just be for small jobs and post-processing. I was going
>> to try gcc and gfortran but wanted to get your thoughts on this
>> before hacking around too much.
>> Thanks,
>> Mark
> Nek5000-users mailing list
