[Nek5000-users] Reset Eig in hsmg setup fast
Paul Fischer fischer at mcs.anl.gov
Fri Jan 9 09:10:40 CST 2009
Hi Johan,
I've encountered that message in the past, but it's generally
just informational.
It's interesting that you're finding a correlation with code
failure -- I certainly want to take a look at that.
If you're using the current repo version of the code, can you
email a tarfile with SIZEu, .rea, and .usr file directly to me?
Paul
On Fri, 9 Jan 2009, Johan Ohlsson wrote:
> Hi Nek5000 users,
> Have you encountered this message: 'Reset Eig in hsmg setup fast' which
> appears in hsmg.f ? I am trying to run a problem with quite many
> elements and I get this message when N is greater than a critical
> number. As soon as N is below this number, everything is fine. It seems
> as some arrays get too big, which make the mg not working correctly and
> eventually I will have NaNs from the hmholtz. What exactly is going on ?
> Johan Ohlsson
> Nek5000-users mailing list
