[Nek5000-users] genbox compiling problems
Tue Dec 29 21:23:39 CST 2009
Hi Harish,
go to nek5_svn/trunk
then
svn update tools
then try to edit / run maketools again with gfortran
For a prenek manual, you might look at the (very dated) manual
  www.mcs.anl.gov/~fischer/nekmanual.pdf
and also:
  www.mcs.anl.gov/~fischer/primer.pdf
Paul
On Tue, 29 Dec 2009, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I am new to Nek5000. I can compile the code with OpenMPI compilers 'mpi77'
> & 'mpicc' and run the code in parallel up to 8 processors. Though, I do
> get some warnings during compilation.
> Then, I wanted to setup a 2D case for flow over a backward facing step and
> run it. This is were I ran into hurdles.
> I could not compile genbox using maketools as it gave me compiling errors.
> The compilers I have specified in the maketools executable are:
> # specify your compilers here
> F77="gfortran"
> CC="gcc"
> Following are the compiling errors:
> [harish at cmtl tools]$ ./maketools genbox
> Make genbox...
> make[1]: Entering directory `/home/harish/nek5_svn/trunk/tools/genbox'
> gfortran -mcmodel=medium -c   genbox.f
> In file genbox.f:648
>                     buf(8) = 'C'
>                              1
> Error: Can't convert CHARACTER(1) to REAL(4) at (1)
> In file genbox.f:1551
>     r  = x(2)
>           1
> Warning: Array reference at (1) is out of bounds
> make[1]: *** [genbox.o] Error 1
> make[1]: Leaving directory `/home/harish/nek5_svn/trunk/tools/genbox'
> make: *** [all] Error 1
> Then, I compiled prenek and used 'prex' for meshing. But, I had trouble
> understanding how to use it. Can you direct me to some resources which
> explain the use of 'prex' for making meshes.
> For the backward facing step, genbox would be most useful to make the mesh
> as it has only 3 boxes and not a complicated geometry. But knowing how to
> use 'prex' would be useful as well.
> Thanks,
> Harish Kanchi.
> Nek5000-users mailing list
