[Nek5000-users] Fixed mass flux
Fri Dec 11 07:28:00 CST 2009
Hi Fred,
in general there are two different ways to do that.
Anyway just have a look how we do it in the turbChannel example.
The general idea is the following:
- call set_forcing() in userchk()  (e.g. call set_forcing(ffx_,xv,1)
- add the acceleration term ffx_ to the momentum eqn. (e.g. set ffx = ffx_ in userf())
Please note that the variable ffx_ has to be visible for userf() and userchk() (e.g. use a common block).
The initial acceleration can be specified by param(71) .
#Stefan
On Dec 11, 2009, at 2:12 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> currently I'm trying to run some simple cases to getting used to the code. But unfortunately I didn't understand how it's possible to predefine a fixed mass flux. Do I just have to enter a fixed value for Parameter 54 resp. 55 in the rea-File? Maybe this question is a little stupid, but whatever I tried, the velocity in the result file .fld* was more or less equal zero..
> Best regards,
> Fred
> Nek5000-users mailing list
