[Nek5000-users] Three questions
Kerkemeier Stefan kerkemeier at lav.mavt.ethz.ch
Sat Aug 1 11:26:27 CDT 2009
1: sure, nek5000 can do that.
I cannot tell you more unless you come up with more details. Depending on the geometry you can use prenek to build a mesh.
2: I am afraid there is no code documentation but the books you were talking about cover more or less everything although not in great technical detail. You will get some informations about the used methods but when it comes to coding it will not really help you.
Best,
Stefan
--- original message ---
Subject: Re: RE: [Nek5000-users] Three questions
Date: 1st August 2009
Time: 5:06:49 pm
Hi Stefan
Thank you for your reply!
There are two other issue in the previous email which I hope you can give me any adivice:
1 What I intend   to do is  an accurate simulation of incompressible  turbulent flow  (with heat  transfer)  around cylinders, my question is :is nek5000 suitable for this simulation?
If it is YES, can I use the mesh generate tools included in nek5000 to create mesh for this case?
I know you are working with Cubit, but I think it is not a free mesh generator.
2 Is there any theoretical manual for me to understand the code ?  It seems very difficult for me to understand what exactly the program is doing without a guide.
I have some back ground on FVM, FEM , right now I study  the book "High-order method for incompressible fluid flow" and "Spectral/hp element methods for CFD"
Regards
Zhicheng
2009-08-01
王志成
发件人: Kerkemeier Stefan
发送时间: 2009-08-01  22:26:26
收件人: wangzhicheng
抄送: Nek5000-users at lists.mcs.anl.gov
主题: RE: [Nek5000-users] Three questions
nek tries to tell you, that the local size lelt is too small for the given number of elements and processors. If you have 9375 elements in total you probably need to run it in parallel. Your local size seems to be 600 elements so you need 16 proc to run the solver or you need to increase the local size lelt in the SIZEu file and recompile.
Hth,
Stefan
From: wangzhicheng <wangzhicheng at mail.etp.ac.cn>
Subject: [Nek5000-users] Three questions
Time: 11:06:00 am
