[mpich-discuss] How can I debug MPI program
clara clarazhang at gmail.com
Fri Jul 29 09:52:44 CDT 2011
Thank you so much.
I use  the below commandline and can debug now.
    mpiexec -n 2 xterm -e gdb cg.S.2
On Thu, Jul 28, 2011 at 9:44 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> On 07/28/2011 12:15 AM, clara wrote:
>> I see. I find mpich2-1.2 supports -gdb, doesn't it?
> mpich2-1.2 had MPD as the default process manager. That was changed to Hydra
> in 1.3 and mpd deprecated.
>> Btw, for the current hydra process manager, we can use totalview to
>> debug program, don't you?
> Yes, totalview, ddt, ddd are all fine. The native gdb itself is supported as
> well. You can even use it as:
> % mpiexec -n 1 xterm -e gdb cg.S.2 : -n 1 xterm -e gdb cg.S.2
> The "-gdb" option within mpd, on the other hand, isn't the native gdb. MPD
> had its own gdb terminal implemented internally which used to manage many
> independent native gdb's. That option is currently not available (till we
> add it).
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
