[mpich-discuss] 回复: 回复: 回复: [mpich- discuss] 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 26 00:16:16 CDT 2011
Ah, sorry, I misread your previous email. Can you try running this:
% ssh hksbs-s13.com env | grep LD_LIBRARY_PATH
  -- Pavan
On 07/25/2011 10:26 PM, 游手好闲 wrote:
> I mean, when i run
> [root at hksbs-s13 ~]#/opt/mpich2-1.4/bin/hydra_pmi_proxy
> [proxy:unset at hksbs-s13.com] HYD_pmcd_pmip_get_params
> (./pm/pmiserv/pmip_utils.c:732): server name not available
> [proxy:unset at hksbs-s13.com] main (./pm/pmiserv/pmip.c:187): bad
> parameters passed to the proxy
> when i run
> [root at hksbs-s13 ~]# ssh hksbs-s13.com /opt/mpich2-1.4/bin/hydra_pmi_proxy
> /opt/mpich2-1.4/bin/hydra_pmi_proxy: error while loading shared
> libraries: libimf.so: cannot open shared object file: No such file or
> directory
> although in the same node(hksbs-s13.com), if I use ssh or not ,the
> result is different.
> Just like when I don't set
> export LD_LIBRARY_PATH= ** in ~/.bash_profile
> because
> source /opt/intel/Compiler/11.1/064/bin/ifortvars.sh intel64
> has the same effect.
> [root at hksbs-s13 ~]# ssh 10.33.15.233 /opt/mpich2-1.4/bin/hydra_pmi_proxy
> directory
> ------------------ 原始邮件 ------------------
> *发件人:* "Pavan Balaji"<balaji at mcs.anl.gov>;
> *发送时间:* 2011年7月26日(星期二) 中午11:14
> *收件人:* "游手好闲"<66152764 at qq.com>;
> *抄送:* "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
> *主题:* Re: 回复: 回复: [mpich- discuss] 转发:回复: hydra_pmi_proxy:
>  > directory
>  > the result is same.
> The output of the above ssh command is clearly different from what you
> sent earlier. Do you mean the mpiexec command's result is the same?
> -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
