[mpich-discuss] 回复: 回复: 回复: [mpich- discuss] 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
游手好闲 66152764 at qq.com
Mon Jul 25 22:26:48 CDT 2011
I mean, when i run
 [root at hksbs-s13 ~]#/opt/mpich2-1.4/bin/hydra_pmi_proxy
 [proxy:unset at hksbs-s13.com] HYD_pmcd_pmip_get_params (./pm/pmiserv/pmip_utils.c:732): server name not available
[proxy:unset at hksbs-s13.com] main (./pm/pmiserv/pmip.c:187): bad parameters passed to the proxy
 when i run
 [root at hksbs-s13 ~]# ssh hksbs-s13.com  /opt/mpich2-1.4/bin/hydra_pmi_proxy
/opt/mpich2-1.4/bin/hydra_pmi_proxy: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory
 although in the same node(hksbs-s13.com), if I use ssh or not ,the result is different.
 Just like when I don't set
 export LD_LIBRARY_PATH= ** in  ~/.bash_profile
 because
  source /opt/intel/Compiler/11.1/064/bin/ifortvars.sh intel64
 has the same effect.
 [root at hksbs-s13 ~]# ssh 10.33.15.233 /opt/mpich2-1.4/bin/hydra_pmi_proxy
  ------------------ 原始邮件 ------------------
  发件人: "Pavan Balaji"<balaji at mcs.anl.gov>;
 发送时间: 2011年7月26日(星期二) 中午11:14
 收件人: "游手好闲"<66152764 at qq.com>;
 抄送: "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
 主题: Re: 回复: 回复: [mpich- discuss] 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
> directory
> the result is same.
The output of the above ssh command is clearly different from what you sent earlier. Do you mean the mpiexec command's result is the same?
 -- Pavan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110726/de1540db/attachment.htm>
