[mpich-discuss] 回复: 回复: 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
游手好闲 66152764 at qq.com
Mon Jul 25 21:37:01 CDT 2011
when i set LD_LIBRARY_PATH in ~/.bash_profile again
 export LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/064/lib/intel64
 and login again.
 root at hksbs-s13 ~]# echo $LD_LIBRARY_PATH
/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64
 [root at hksbs-s13 ~]# ssh 10.33.15.233 /opt/mpich2-1.4/bin/hydra_pmi_proxy
/opt/mpich2-1.4/bin/hydra_pmi_proxy: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory
 the result is same.
  ------------------ 原始邮件 ------------------
  发件人: "Pavan Balaji"<balaji at mcs.anl.gov>;
 发送时间: 2011年7月26日(星期二) 上午10:22
 收件人: "游手好闲"<66152764 at qq.com>;
 抄送: "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
 主题: Re: 回复: [mpich-discuss] 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
On 07/25/2011 09:19 PM, 游手好闲 wrote:
> [root at hksbs-s11 ~]# env | grep LD_LIBRARY_PATH
> LD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64:/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64
> DYLD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/cce/10.1.018/lib
> [root at hksbs-s11 ~]# ssh hksbs-s13.com env | grep LD_LIBRARY_PATH
Is your LD_LIBRARY_PATH not set in your shell startup script?
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110726/ddfcf812/attachment.htm>
