[mpich-discuss] MPI_Send in 32bit mpich2 (1.4) hangs in 64bit win7
shridhar mohan shri.emi at gmail.com
Thu Jul 21 15:30:47 CDT 2011
Hello ,
I have been reading through the mailing lists
and i must say you guys are doing a nice job.
I started to set up MPICH2 last week.
We have cluster of 5 computers running 64-bit win 7.
I installed 64-bit  Mpich2 ver 1.4 in three of the machines.
Turned the Firewall down.
Smpd -status on each machine return's running.
However when i try to find the status of other hosts
it simply times out.
So uninstalled 64 bit and installed 32-bit as instructed
in section 9.4 of the installation guide.
Everything seems to be fine in 32 bit.
I was able to run "hello world" using multiple hosts.
But, when i try to send data using MPI_Send from
one host to the other, It simply hangs.
However, process within the same host are able to
send and receive data using MPI_Send.
This is very puzzling to me,
Am I doing anything wrong.
It will be helpful if someone can point me in the
right direction.
-Thanks
shridhar
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110721/9e6b05e7/attachment.htm>
