[mpich-discuss] mpich2-1.4 installation error
Ruhollah Moussavi Baygi ruhollah at berkeley.edu
Mon Jul 18 16:25:12 CDT 2011
Hi there
I have only ordinary user privileges and so trying to install MPICH2 in my
home directory. there was a problem and couldn't figure it out.
here are my c.txt, m.txt, and config.log files.
thank you for your help.
PS by the way, our cluster is such that my directory is shared between all
nodes and thus all nodes have equally access.
Best,
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110718/3ec9a90e/attachment-0001.htm>
Configuring MPICH2 version 1.4 with  '--prefix' '/home/ruhollah/mpich2_installed/'
Running on system: Linux avicennanode19 2.6.20-krg #1 SMP Sun Nov 28 22:32:42 UTC 2010 x86_64 GNU/Linux
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for grep that handles long lines and -e... /bin/grep
checking for fgrep... /bin/grep -F
Executing mpich2prereq in /home/ruhollah/source-mpich2-1.4/src/mpid/ch3 with
Executing mpich2prereq in /home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/mpl/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 98304
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... no
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/openpa/configure --with-atomic-primitives=auto_allow_emulation '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 8
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /home/ruhollah/source-mpich2-1.4/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking for multiple weak symbol support... yes
checking for ifort... ifort
checking whether we are using the GNU Fortran 77 compiler... no
checking whether ifort accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from ifort... -v
checking for Fortran 77 libraries of ifort...  -L/opt/intel/composerxe-2011.1.107/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -L/lib64 -L/lib -L/usr/lib64 -L/usr/lib -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
checking whether ifort accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking whether we are using the GNU Fortran compiler... no
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (ifort    ) works... yes
checking whether the Fortran 90 compiler (ifort    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) no
checking whether ifort accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... intel
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 2
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... killall
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... no
checking whether make allows comments in actions... no
configure: WARNING: Your make does not allow comments in target code.
Using this make may cause problems when building programs.
You should consider using gnumake instead.
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... sixteen
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... sixteen
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 8
checking size of unsigned long... 8
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 16
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 16
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 32
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 32
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is -1 and False is 0
checking for BSD/POSIX style global symbol lister... BSD style,/usr/bin/nm -g -B
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 16
checking the minimum alignment of Fortran common block of 5 integers... 16, too small! reset to 32
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 32
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 88
checking for gcc __asm__ and pentium cmpxchgl instruction... no
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... yes
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
sourcing /home/ruhollah/source-mpich2-1.4/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... no
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/mpid/ch3/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/configure  '--prefix' '/home/ruhollah/mpich2_installed/' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/mpi/romio/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
Configuring with args --prefix /home/ruhollah/mpich2_installed/ --disable-option-checking
checking for architecture... LINUX
ROMIO home directory is /home/ruhollah/source-mpich2-1.4/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... no
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to ifort
setting TEST_CC to /home/ruhollah/source-mpich2-1.4/bin/mpicc
setting TEST_F77 to /home/ruhollah/source-mpich2-1.4/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/simple =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/pmi/simple/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: ===== done with src/pmi/simple configure =====
configure: ===== configuring src/pm/hydra =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/pm/hydra/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
checking for a thread-safe mkdir -p... mkdir -p
checking whether -lc should be explicitly linked in... no
checking whether to build shared libraries... yes
checking for doxygen... no
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking bootstrap server... ssh,rsh,fork,slurm,ll,lsf,sge,pbs,none,persist
checking process manager... pmiserv
checking user interface... mpich
checking desired process binding libraries... hwloc,plpa
configure: ===== configuring tools/bind/hwloc/hwloc =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc/configure --enable-embedded-mode '--prefix' '/home/ruhollah/mpich2_installed/' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' --disable-option-checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... x86_64-unknown-linux-gnu
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.2rc3-1
checking whether gcc and cc understand -c and -o together... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /home/ruhollah/source-mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc
configure: hwloc srcdir: /home/ruhollah/source-mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking which OS support to include... Linux
checking which CPU support to include... x86_64
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... no
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... no
checking for __attribute__(hot)... no
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... no
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility... yes
checking whether to enable visibility... yes (via -fvisibility=hidden)
configure: WARNING: " -fvisibility=hidden" has been added to the hwloc CFLAGS
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking for sysctl... yes
checking for sysctlbyname... no
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... yes
checking for printf... yes
checking for final KERRIGHED support... yes
checking for lib... no
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... no
checking for cpuid... yes
checking for X... no
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating include/private/autogen/config.h
config.status: include/private/autogen/config.h is unchanged
config.status: creating include/hwloc/autogen/config.h
config.status: include/hwloc/autogen/config.h is unchanged
configure: ===== done with tools/bind/hwloc/hwloc configure =====
configure: ===== configuring tools/bind/plpa/plpa =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/pm/hydra/tools/bind/plpa/plpa/configure --enable-included-mode '--prefix' '/home/ruhollah/mpich2_installed/' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' --disable-option-checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... no
checking for lex... no
checking for bison... no
checking for byacc... no
checking for syscall... yes
checking sys/syscall.h usability... yes
checking sys/syscall.h presence... yes
checking for sys/syscall.h... yes
checking for __NR_sched_setaffinity... yes
checking for __NR_sched_getaffinity... yes
checking for PLPA building mode... included
checking if want PLPA maintainer support... disabled
checking for PLPA config prefix... .
checking for PLPA symbol prefix... plpa_
configure: WARNING: valgrind.h not found
checking whether to build PLPA executables... no
config.status: creating ./Makefile
config.status: creating ./config/Makefile
config.status: creating ./src/Makefile
config.status: creating ./src/libplpa/Makefile
config.status: creating ./src/plpa-info/Makefile
config.status: creating ./src/plpa-taskset/Makefile
config.status: creating ./src/libplpa/plpa_config.h
config.status: ./src/libplpa/plpa_config.h is unchanged
config.status: creating ./src/libplpa/plpa.h
config.status: ./src/libplpa/plpa.h is unchanged
configure: ===== done with tools/bind/plpa/plpa configure =====
checking available process binding libraries... hwloc plpa
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... yes
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: include/hydra_config.h is unchanged
configure: ===== done with src/pm/hydra configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /home/ruhollah/source-mpich2-1.4/src/mpe2/configure  '--prefix' '/home/ruhollah/mpich2_installed/' --disable-option-checking
Configuring MPE Profiling System with  '--prefix' '/home/ruhollah/mpich2_installed/' '--disable-option-checking' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2
checking gnumake... no
checking BSD 4.4 make... Found BSD 4.4 so-called make
The BSD 4.4 make is INCOMPATIBLE with all other makes.
Using this so-called make may cause problems when building programs.
checking OSF V3 make... Found OSF V3 make
The OSF V3 make does not allow comments in target code.
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/collchk" cleaned
checking whether MPI_CC has been set ... /home/ruhollah/source-mpich2-1.4/bin/mpicc
checking whether MPI_F77 has been set ... /home/ruhollah/source-mpich2-1.4/bin/mpif77
checking for Fortran 77 libraries of ifort...  -L/opt/intel/composerxe-2011.1.107/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -L/lib64 -L/lib -L/usr/lib64 -L/usr/lib -lrt -lpthread -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl
checking whether C can link with  -L/opt/intel/composerxe-2011.1.107/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -L/lib64 -L/lib -L/usr/lib64 -L/usr/lib -lrt -lpthread -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/misc)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/ruhollah/mpich2_installed'  'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/misc
checking for dbx... no
checking for gdb... no
checking for sysinfo... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/callstack
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int64_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/wrappers
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/graphics
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
configure: WARNING:  Could not find appropriate X windows libraries.  MPE routines that make use of X11 graphics will NOT be built unless you put X windows libraries in your path and reconfigure!
=== configuring in src/collchk (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/collchk
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for ar... ar
checking for ranlib... ranlib
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/home/ruhollah/source-mpich2-1.4/src/mpe2/src/slog2sdk)
checking for current directory name... /home/ruhollah/source-mpich2-1.4/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/home/ruhollah/mpich2_installed' 'MPI_CC=/home/ruhollah/source-mpich2-1.4/bin/mpicc' 'MPI_F77=/home/ruhollah/source-mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers' 'F77=ifort' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for a BSD-compatible install... /usr/bin/install -c
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... not found
configure: WARNING:  No Java Virtual Machine can be found anywhere!
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/collchk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 8
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
Running Configure for Fortran 90 Type routines
checking for fgrep... /bin/grep -F
checking for an ANSI C-conforming const... yes
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
configure: creating ./config.status
config.status: creating mpif90model.h
config.status: creating Makefile
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpix/Makefile
config.status: creating src/mpix/comm/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/Makefile
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: src/include/mpichconf.h is unchanged
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
=== configuring in test/mpi (/home/ruhollah/source-mpich2-1.4/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/ruhollah/mpich2_installed'  --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking whether /home/ruhollah/source-mpich2-1.4/bin/mpicc accepts -g... yes
checking for /home/ruhollah/source-mpich2-1.4/bin/mpicc option to accept ISO C89... none needed
checking for C/C++ restrict keyword... __restrict
checking how to run the C preprocessor... /home/ruhollah/source-mpich2-1.4/bin/mpicc -E
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for library containing pthread_create... -lpthread
checking for library containing pthread_barrier_init... none required
checking for pthread_create... yes
checking for pthread_yield... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether we are using the GNU Fortran 77 compiler... no
checking whether /home/ruhollah/source-mpich2-1.4/bin/mpif77 accepts -g... yes
checking how to get verbose linking output from /home/ruhollah/source-mpich2-1.4/bin/mpif77... -v
checking for Fortran 77 libraries of /home/ruhollah/source-mpich2-1.4/bin/mpif77...  -L/opt/intel/composerxe-2011.1.107/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -L/lib64 -L/lib -L/usr/lib64 -L/usr/lib -lpthread -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl
checking for Fortran 77 name mangling... lower uscore
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... yes
checking for Fortran 77 compiler flag for Cray-style pointer... none
checking whether we are using the GNU Fortran compiler... no
checking whether /home/ruhollah/source-mpich2-1.4/bin/mpif90 accepts -g... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (/home/ruhollah/source-mpich2-1.4/bin/mpif90  -nativelinking  ) works... yes
checking whether the Fortran 90 compiler (/home/ruhollah/source-mpich2-1.4/bin/mpif90  -nativelinking  ) is a cross-compiler... no
checking for Fortran flag needed to accept free-form source... none
checking whether Fortran 90 supports Cray-style pointer... yes
checking for Fortran 90 compiler flag for Cray-style pointer... none
checking whether we are using the GNU C++ compiler... yes
checking whether /home/ruhollah/source-mpich2-1.4/bin/mpicxx accepts -g... yes
checking whether <iostream> available... yes
checking whether the compiler implements namespaces... yes
checking whether the compiler implements the namespace std... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... 8
checking size of int... 4
checking size of long... 8
checking size of long long... 8
checking size of short... 2
checking for C integer type of address size... long
checking for perl... /usr/bin/perl
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
Configuration completed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110718/3ec9a90e/attachment-0001.obj>
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='ifort' FFLAGS='  -O2' FC='ifort' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers'
make all-local
make[1]: Entering directory `/home/ruhollah/source-mpich2-1.4'
make[1]: Leaving directory `/home/ruhollah/source-mpich2-1.4'
make[1]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
make[1]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpl'
make[1]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/openpa'
Making all in src
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/openpa/src'
make  all-am
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/openpa/src'
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/bash ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o libopa.la -rpath /home/ruhollah/mpich2_installed/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/openpa/src'
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/openpa/src'
Making all in test
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/openpa/test'
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/openpa'
make[1]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/openpa'
make[1]: Entering directory `/home/ruhollah/source-mpich2-1.4/src'
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpl'
make[2]: Warning: File `.deps/mpltrmem.Plo' has modification time 3.4e+03 s in the future
make[2]: warning:  Clock skew detected.  Your build may be incomplete.
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpl'
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common'
make[4]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype'
make[5]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype/dataloop'
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c segment_packunpack.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c segment_flatten.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c segment_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_contig.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dataloop_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c subarray_support.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c darray_support.c
ar cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
ranlib ../../../../../lib/libmpich.a
date > .libstamp0
make[5]: Warning: File `../../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[5]: warning:  Clock skew detected.  Your build may be incomplete.
make[5]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_debug.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_ext32_segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_ext32_datatype.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpir_type_get_contig_blocks.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpir_type_flatten.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_commit.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_zerolen.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_datatype_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_datatype_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_type_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_contents_support.c
ar cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[5]: Warning: File `../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[5]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype'
make[4]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype'
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/common'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3'
make[4]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels'
make[5]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_alloc.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_queue.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_barrier.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_mpich2.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_ckpt.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_network_poll.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_network.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_debug.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_lmt.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_lmt_shm.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_net_array.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_lmt_dma.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_nem_lmt_vmsplice.c
ar cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
ranlib ../../../../../../../lib/libmpich.a
date > .libstamp0
make[7]: Warning: File `../../../../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[7]: warning:  Clock skew detected.  Your build may be incomplete.
make[7]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_utility.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c socksm.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_getip.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c tcp_ckpt.c
ar cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
ranlib ../../../../../../../../lib/libmpich.a
date > .libstamp0
make[8]: Warning: File `../../../../../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[8]: warning:  Clock skew detected.  Your build may be incomplete.
make[8]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c papi_defs.c
ar cr ../../../../../../../../lib/libmpich.a papi_defs.o
date > .libstamp0
make[8]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mkstemp.c
ar cr ../../../../../../../../lib/libmpich.a mkstemp.o
date > .libstamp0
make[8]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_isendv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_istartmsg.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_istartmsgv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_progress.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3_abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3i_comm.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3i_eagernoncontig.c
ar cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
ranlib ../../../../../../lib/libmpich.a
date > .libstamp0
make[6]: Warning: File `../../../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[6]: warning:  Clock skew detected.  Your build may be incomplete.
make[6]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels'
make[4]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/src'
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_buffer.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_handle_connection.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_handle_recv_pkt.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_handle_recv_req.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_handle_send_req.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_recvq.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_request.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_rma_ops.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_rma_sync.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_rndv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_eager.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ch3u_eagersync.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_cancel_recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_cancel_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_get_universe_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_getpname.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_iprobe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_irecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_irsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_issend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_probe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_rsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_ssend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_startall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_vc.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpid_rma.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpidi_isend_self.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpidi_pg.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpidi_printf.c
ar cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[4]: Warning: File `../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[4]: warning:  Clock skew detected.  Your build may be incomplete.
make[4]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/src'
make[4]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/util'
make[4]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/util'
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid/ch3'
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpid'
make[2]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c attr_delete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c attr_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c attr_put.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c keyval_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c keyval_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c attrutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dup_fn.c
ar cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Warning: File `../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[3]: warning:  Clock skew detected.  Your build may be incomplete.
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/attr'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c allreduce.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c barrier.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c op_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c op_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c bcast.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c alltoall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c alltoallv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c reduce.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c scatter.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c gather.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c scatterv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c gatherv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c scan.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c exscan.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c allgather.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c allgatherv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c red_scat.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c alltoallw.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c reduce_local.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c op_commutative.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c red_scat_block.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c helper_fns.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opsum.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opmax.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opmin.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opband.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opbor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opbxor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opland.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c oplor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c oplxor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opprod.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opminloc.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c opmaxloc.c
ar cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/coll'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_compare.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_remote_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_remote_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_split.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_test_inter.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c intercomm_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c intercomm_merge.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c commutil.c
ar cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Warning: File `../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[3]: warning:  Clock skew detected.  Your build may be incomplete.
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/comm'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c address.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_address.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_elements.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c pack.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c unpack.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c pack_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c status_set_elements.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_commit.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_hvector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_ub.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_lb.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_get_true_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_match_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_hvector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c pack_external.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c pack_external_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c unpack_external.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_indexed_block.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_darray.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c type_create_subarray.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c typeutil.c
ar cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/datatype'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c add_error_code.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c add_error_class.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c add_error_string.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c errhandler_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c errhandler_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c errhandler_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c errhandler_set.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c error_class.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c error_string.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c errutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dynerrutil.c
ar cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Warning: File `../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[3]: warning:  Clock skew detected.  Your build may be incomplete.
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/errhan'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_compare.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_difference.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_excl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_incl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_intersection.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_range_excl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_range_incl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_translate_ranks.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c group_union.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c grouputil.c
ar cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/group'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c initialized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c initthread.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ismain.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c finalized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c querythread.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c initinfo.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpi/spawn -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c async.c
ar cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/init'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c getpname.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c pcontrol.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c version.c
ar cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/misc'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c bsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c bsend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c bufattach.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c buffree.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cancel.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c greq_start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c greq_complete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ibsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iprobe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c irecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c irsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c issend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c probe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c recv_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c request_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c request_get_status.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c rsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c rsend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c send_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c sendrecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c sendrecv_rep.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c status_set_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ssend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ssend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c startall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c test_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c testall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c testany.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c testsome.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c wait.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c waitall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c waitany.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c waitsome.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c bsendutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpir_request.c
ar cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Warning: File `../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[3]: warning:  Clock skew detected.  Your build may be incomplete.
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/pt2pt'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c accumulate.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c alloc_mem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c free_mem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c put.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_complete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_fence.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_get_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_lock.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_post.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_unlock.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_wait.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c win_test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c winutil.c
ar cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/rma'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_get_parent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_join.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_spawn.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c lookup_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c publish_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c unpublish_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c open_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c close_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_connect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c comm_accept.c
ar cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/spawn'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c wtime.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c wtick.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/ruhollah/source-mpich2-1.4/src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpidtime.c
ar cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
date > .libstamp0
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/timer'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_coords.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_map.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_shift.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cart_sub.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dims_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graph_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graph_map.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graph_nbr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graphcreate.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graphdimsget.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c graphnbrcnt.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cartdim_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c topo_test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dist_gr_create_adj.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dist_gr_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dist_gr_neighb_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c dist_gr_neighb.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c topoutil.c
ar cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Warning: File `../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[3]: warning:  Clock skew detected.  Your build may be incomplete.
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/topo'
make[3]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io'
make[5]: Warning: File `/home/ruhollah/source-mpich2-1.4/lib/libmpich.a' has modification time 3.4e+03 s in the future
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c close.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c open.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c set_view.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iread.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iwrite.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c seek.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_posn.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c delete.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_all.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_at.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_atall.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iread_at.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iwrite_at.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_all.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_bytoff.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_at.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_atall.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_view.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_group.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_amode.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_extent.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c fsync.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_atom.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c set_atom.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c set_size.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_size.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c prealloc.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_f2c.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c file_c2f.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c set_info.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_info.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c rd_atallb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c rd_atalle.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_allb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_alle.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c wr_atallb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c wr_atalle.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_allb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_alle.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_posn_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iread_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iwrite_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c seek_sh.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_ord.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_orde.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_ordb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c read_ordb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_ord.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c write_orde.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpiu_greq.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpich2_fileutil.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c register_datarep.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io -I../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c mpir-mpioinit.c
ar cr /home/ruhollah/source-mpich2-1.4/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o mpir-mpioinit.o
ranlib /home/ruhollah/source-mpich2-1.4/lib/libmpich.a
make[5]: warning:  Clock skew detected.  Your build may be incomplete.
make[5]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common'
make[5]: Warning: File `/home/ruhollah/source-mpich2-1.4/lib/libmpich.a' has modification time 3.4e+03 s in the future
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_close.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_init.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_end.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_open.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c flatten.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c malloc.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_read_coll.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c eof_offset.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_write_coll.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c lock.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_read_str.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_write_str.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c iscontig.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c get_fp_posn.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_seek.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_delete.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_flush.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_hints.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c error.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_fstype.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_get_sh_fp.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_set_sh_fp.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c shfp_fname.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c byte_offset.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c status_setb.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_aggregate.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c cb_config_list.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_read_str_naive.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_set_view.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_iopen.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_write_str_naive.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_resize.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_read.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_write.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_iread.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_iwrite.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_done.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_wait.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c adi_close.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_prealloc.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_fcntl.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_iread_fake.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_iwrite_fake.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_done_fake.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_wait_fake.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_subarray.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c ad_darray.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c strfns.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c greq_fns.c
gcc -I. -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/mpl/include -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/openpa/src -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/datatype -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/common/locks -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -I/home/ruhollah/source-mpich2-1.4/src/util/wrappers -c system_hints.c
system_hints.c:188: fatal error: error closing /tmp/ccJiOc0J.s: Interrupted system call
compilation terminated.
make[5]: *** [system_hints.o] Error 1
make[5]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio/adio/common'
make[4]: *** [mpiolib] Error 1
make[4]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio'
make[3]: *** [mpio] Error 2
make[3]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi/romio'
make[2]: *** [all-redirect] Error 1
make[2]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src/mpi'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/home/ruhollah/source-mpich2-1.4/src'
make: *** [all-redirect] Error 2
