[mpich-discuss] ssh passwordless works fine, but mpdboot still needs password.
Reuti reuti at staff.uni-marburg.de
Sun Jul 17 04:45:38 CDT 2011
Am 17.07.2011 um 07:33 schrieb greatlzy:
> I want to setup a local network MPI environment (only 2 machines).
> I have set the same username(abc) and the same password(123) on machine A and machine B ,and ssh passworless works fine on both side.
You connect from another machine C to A and B, or is A your desktop one?
> I installed the mpich2 on machine A (/mpich), the file .mpd.conf is in /home/abc , the file mpd.hosts is in /mpich.
> and export the dir (/mpich) and /home/abc using NFS server,then machine B mounts them to /mpich and /home/mpich respectively.
> In machine A, the command "mpdboot -n 2 -f /cluster/mpd.hosts" prompts to intput the password of the user abc on machineB, when I input the passwrod '123', mpd starts successfully.
> Why mpdboot needs abc at machineB's password? What should I do?
> Thanks a lot
> ubuntu 11.04
> mpich2-1.0.8
Please try the latest version 1.4 which doesn't use mpd any longer but a daemonless startup of the tasks on slave nodes. You can compile it on your into $HOME/local/mpich2-1.4 or alike and set an appropriate PATH thereto.
Was the 1.0.8 instealled ubuntu by default?
-- Reuti
> Li Zhiyu
> student in GUCAS
> 2011-07-17
> greatlzy
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
