[mpich-discuss] ssh passwordless works fine, but mpdboot still needs password.
greatlzy greatlzy at sina.com
Sun Jul 17 00:33:53 CDT 2011
I want to setup a local network MPI environment (only 2 machines).
I have set the same username(abc) and the same password(123) on machine A and machine B ,and ssh passworless works fine on both side.
I installed the mpich2 on machine A (/mpich), the file .mpd.conf is in /home/abc , the file mpd.hosts is in /mpich.
and export the dir (/mpich) and /home/abc using NFS server,then machine B mounts them to /mpich and /home/mpich respectively.
In machine A, the command "mpdboot -n 2 -f /cluster/mpd.hosts" prompts to intput the password of the user abc on machineB, when I input the passwrod '123', mpd starts successfully.
Why mpdboot needs abc at machineB's password? What should I do?
Thanks a lot
ubuntu 11.04
mpich2-1.0.8
Li Zhiyu
student in GUCAS
2011-07-17
greatlzy
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110717/778fd451/attachment.htm>
