[mpich-discuss] MPICH2-1.4 make error
Anthony Chan chan at mcs.anl.gov
Sat Jul 9 19:01:27 CDT 2011
The last line in your c.txt contains this:
configure: error: F90 and F90FLAGS are replaced by FC and FCFLAGS respectively in this configure, please unset F90/F90FLAGS and set FC/FCFLAGS instead and rerun configure again.
So mpich2 configure failed because of you have either F90 or F90FLAGS (or both)
set in your environment during configure.  Unset them and try again.
(It is likely that you set these variables in your shell startup file)
BTW, the config.log you sent isn't the top-level one, it is from mpich2-1.4/src/openpa
so I cannot tell which exact F90* you set.
A.Chan
----- Original Message -----
> Dear users,
> I have been trying to install MPICH2 library using gfortran (4.1.2
> version).
> Everything works fine while configuration, however when I try to make
> the
> code, it gives following error:
> make: *** No targets specified and no makefile found. Stop.
> Further it is to be noted that *no* Makefile was actually formed after
> the
> configuration step.
> I have attached the c.txt and config.log file for your reference.
> It would be great if somebody could throw some light on this error!
> Thanks and Regards,
> nilima
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
