[mpich-discuss] (MPICH2 64-bit) wmpiconfig states that MPICH2 not installed or unable to query the host
Jayesh Krishna jayesh at mcs.anl.gov
Fri Feb 25 11:36:25 CST 2011
 Hmmm... I can reproduce the problem here at the lab. I have created a ticket on this issue (https://trac.mcs.anl.gov/projects/mpich2/ticket/1443).
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Friday, February 25, 2011 8:34:10 AM
Subject: RE: [mpich-discuss] (MPICH2 64-bit) wmpiconfig states that MPICH2 not	installed or unable to query the host
Hi Jayesh,
Thank you kindly for the reply.
I am trying to configure localhost (only). I excluded the nodes for simplicity(so far).
Oleg
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, February 25, 2011 4:14 PM
Cc: gamov at kipt.kharkov.ua
Subject: Re: [mpich-discuss] (MPICH2 64-bit) wmpiconfig states that MPICH2 not installed or unable to query the host
>> Different 64-bit versions work fine except one thing ...
 Are you having different versions of MPICH2 on the different nodes ? Are you trying to configure the localhost or a remote host (If so, does the remote node/host have a 64-bit version of MPICH2 - assuming the localhost is 64-bit)?
Jayesh
Sent: Friday, February 25, 2011 4:24:13 AM
Subject: [mpich-discuss] (MPICH2 64-bit) wmpiconfig states that MPICH2 not	installed or unable to query the host
We have been successfully using MPICH2 (32-bit) for several years.
Recently, we have decided to try a 64-bit version of MPICH2. Different 64-bit versions work fine except one thing: wmpiconfig states that MPICH2 not installed or unable to query the host (even locally).
What could be wrong (how can I fix this bug)?
Sincerely,
Oleg
mpich-discuss mailing list
