[mpich-discuss] unable to get host address
Alex Theiakos Alexios.Theiakos at student.uva.nl
Wed Feb 23 10:13:04 CST 2011
Dear Nicolas,
First thx for your support, I really appreciate it!
Now to your questions,
--I'm running on 10.6.6 all updates done.
--Hosts file is clean, exactly the same as yours.
--I believe i'm not behind a NAT, with ifconfig i'm getting ip's on en0 and en1 profiles (other than the usual 195. or 10. ones )
--I tried the scutil command but nothing changed, still getting the same output.
Just for the record I compiled the openmpi (no offense guys) this morning to see if it would work and it does...
However I would like to check MPICH2, if we can manage to work this out...
Alex
On Feb 23, 2011, at 4:41 PM, Nicolas Rosner wrote:
> Dear Alex,
> Looks to me like something on your side is triggering a possible bug I
> believe to have spotted in sock.c, but I still can't seem to reproduce
> it the way it's happening to you.
> I'm missing an important factor that those last values, odd as some
> may be, don't seem to account for. If I'm not seeing ghosts, I'll
> report the details later.
> More questions, if you don't mind:
> * What version of OS X are you running?
> * Do you remember having modified the original /etc/hosts file? If it
> contains any entries besides the ones in the one I enclose below,
> would you please post its contents?
> * Are you behind a NAT router, or directly connected to an ISP? (Does
> ifconfig | grep 'UP\|inet\b'  show any IP address that doesn't start
> with either 192.168.x.x, 10.0.x.x or 127.0.x.x?)
> * Does anything change if you run (assuming you can and don't mind trying)
>   sudo scutil --set HostName alexmac
> and then retry, eventually adding if need be
>   mpiexec -n 2 -hosts alexmac ./a.out
> where "alexmac" can be any fresh (previously unused) name you like?
> Thanks,
> Nicolás
> Here are comparable values from the freshly installed MacBook (where
> MPICH2 builds and runs fine, although on an internal IP addr). This is
> just for future reference: though related, I don't think it's by
> itself the main cause.
> hostname: Rogers-MacBook-Pro.local
> hostname -s: Rogers-MacBook-Pro
> scutil --get HostName: HostName: not set
> scutil --get LocalHostName: Rogers-MacBook-Pro
> scutil --get ComputerName: Roger’s MacBook Pro
> And here's the default /etc/hosts file from OS X 10.6.x:
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting.  Do not change this entry.
> 127.0.0.1 localhost
> 255.255.255.255  broadcasthost
> ::1  localhost
> fe80::1%lo0  localhost
> On Wed, Feb 23, 2011 at 10:52 AM, Alex Theiakos
> <Alexios.Theiakos at student.uva.nl> wrote:
>> Dear Nicolas,
>> hostname: 145.116.14.woonstichting.de.key.invalid
>> hostname -s:  145
>> scutil --get LocalHostName: lelos
>> Regards,
>> Alex
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
