[mpich-discuss] Interesting Problem
Evans Jeffrey jje at purdue.edu
Sat Feb 19 07:46:42 CST 2011
Thanks Pavan,
Do all the patches need to be applied, a subset, or just one?
Is there a readme that helps with the patch installation process? or do I need to rebuild the library from scratch?
Finally, do these patches appear in a more recent build - like p1?
Thanks again,
Jeff
On Feb 18, 2011, at 4:43 PM, Pavan Balaji wrote:
> On 02/18/2011 09:38 AM, Evans Jeffrey wrote:
>> Done, output attached. I probably won't be able to look at it myself
>> for a while. I have also attached the PBS script (It's short) and the
>> host file. Thanks for any hints or suggestions.
> Hmm.. Looks like this got fixed on trunk earlier. This is the third bug
> report I got today about something that was fixed after 1.3.2 was
> released :-). Here are the relevant patches, if you care:
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7873/mpich2/trunk/src/pm/hydra
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7884/mpich2/trunk/src/pm/hydra
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7904/mpich2/trunk/src/pm/hydra
> Alternatively, you can try out the nightly snapshot to make sure it
> works fine for you:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Jeffrey J. Evans
jje at purdue.edu
http://web.ics.purdue.edu/~evans6/
