[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Pavan Balaji balaji at mcs.anl.gov
Fri Feb 18 10:47:19 CST 2011
Setting the HYDRA_BOOTSTRAP and HYDRA_BOOTSTRAP_EXEC environment
variables should work. What error are you seeing?
Alternatively, you can reconfigure MPICH2 as with
--with-hydra-bss=rsh,ssh,fork,slurm,ll,lsf,sge,pbs,none,persist
This will reprioritize the launchers to give a higher priority to rsh.
  -- Pavan
On 02/18/2011 10:39 AM, Limin Gu wrote:
> Hi,
> I have successfully built and run mpich 1.3.2 on our cluster. But since
> we rather use bprsh (rsh like) between nodes, I have to specify the
> bootstrap at mpiexec command line, like this:
> mpiexec -bootstrap rsh -bootstrap-exec /usr/bin/bprsh
> It works, but is there a way that I can make rsh as the default
> bootstrap in some config file, so I don't have to specify that on every
> mpiexec command?
> I have tried to set HYDRA_BOOTSTRAP and HYDRA_BOOTSTRAP_EXEC environment
> variables, that didn't work.
> Thank you!
> Limin
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
