[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Limin Gu lgu at penguincomputing.com
Fri Feb 18 10:39:48 CST 2011
I have successfully built and run mpich 1.3.2 on our cluster. But since we
rather use bprsh (rsh like) between nodes, I have to specify the bootstrap
at mpiexec command line, like this:
mpiexec -bootstrap rsh -bootstrap-exec /usr/bin/bprsh
It works, but is there a way that I can make rsh as the default bootstrap in
some config file, so I don't have to specify that on every mpiexec command?
I have tried to set HYDRA_BOOTSTRAP and HYDRA_BOOTSTRAP_EXEC environment
variables, that didn't work.
Thank you!
Limin
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110218/c3000e9d/attachment.htm>
